How to install iptables extensions? I get "Extension owner revision 0 not supported"
I'm trying to do
sudo iptables --append OUTPUT --match owner --gid-owner allow-net --jump ACCEPT
which works on my desktop but when I try to do it on the pinephone I get
Warning: Extension owner revision 0 not supported, missing kernel modules?
iptables: No chain/target/match by that name.
The owner iptables extension seems to be installed though because I can do
sudo iptables --match owner -h
and I get the man page for owner
  link for supported pinephone os manjharo et all penguins_rule 2 239 03-19-2024, 10:36 AM
Last Post: penguins_rule
  Can't install Manjaro thorensjubilee 1 1,029 02-09-2023, 08:17 AM
Last Post: thorensjubilee
  Can't install software via Discover or Terminal Kimberley van Buyten 2 1,565 06-10-2022, 02:13 AM
Last Post: shulamy
  Chatty -- no response after install tckosvic 0 1,111 12-11-2021, 09:55 AM
Last Post: tckosvic
  After fresh install outbound phone calls not working. tckosvic 2 2,359 11-10-2021, 10:45 AM
Last Post: tckosvic
  How do you install VPN so you can set up a config file, tor, signal and disk encrypt? temp0rary 5 3,947 05-30-2021, 08:14 PM
Last Post: temp0rary
  Can i install 16 different distros apart from the default manjaro? temp0rary 4 3,931 05-28-2021, 03:55 PM
  Manjaro Original Install + Phosh & Plasma on Multiboot - All Fracked After Upgrades Diagon 0 1,583 01-16-2021, 02:45 AM
Last Post: Diagon
  Install Anbox on Manjaro plasma-mobile help paju1986 11 18,092 11-21-2020, 12:35 AM
Last Post: hiimtye
