Can't install software via Discover or Terminal
Oke, I'ved tried to install Signal but whatever I do, I get a lot of error and don't know why!
First the easy way, install Manjaro, configure it and go to Discover and search for Signal. Once clicked on it, immediately the first error:
signal-desktop;5.43.0-1;aarch64;community: could not find or read package
I ignore that and I press the install button and after a few seconds I get the next error:
Package download failed
So I'm going to try it with the Terminal! First enable snapd, with
$ sudo pacman -S snapd
Guess what! I get a couple of errors, with the first line:
snapd-2.55.5-1-aarch64.pkg.tar.zst failed to downloaderror: failed retrieving file 'snapd-2.55.5-1-aarch64.pkg.tar.zst' from manjaro.moron.eu : The requested URL returned error: 404
Is there something I need to do before? Or is there something with the image I chooses?
Well, I don't know how but I installed Signal Desktop, but it's not functional as a Signal Web app. So don't waste your time Smile
you may try to install axolotl with pamac
ezik
  pacman vs. Discover - again jojuma 4 1,586 05-17-2023, 10:37 PM
  Discover - "He's dead, Jim" jojuma 7 2,772 03-06-2023, 08:11 PM
Last Post: rocket2nfinity
  Can't install Manjaro thorensjubilee 1 1,032 02-09-2023, 08:17 AM
Last Post: thorensjubilee
  How to install iptables extensions? I get "Extension owner revision 0 not supported" anon4 0 2,146 08-27-2022, 12:19 PM
Last Post: anon4
  fldigi software? drspastic 1 1,325 05-14-2022, 11:32 AM
Last Post: programmin
  Discover crashing (terminal output included). allworlds 1 1,383 05-05-2022, 06:46 AM
Last Post: allworlds
  "Emergency" terminal on pinephone (with default setup) altulke 5 2,685 05-03-2022, 12:42 PM
Last Post: altulke
  Chatty -- no response after install tckosvic 0 1,114 12-11-2021, 09:55 AM
Last Post: tckosvic
  Pacman vs. Discover jojuma 3 2,886 11-30-2021, 10:48 AM
Last Post: ryo
  After fresh install outbound phone calls not working. tckosvic 2 2,365 11-10-2021, 10:45 AM
Last Post: tckosvic
