pacman vs. Discover - again
some time ago I was told to run updates via pacman since Discover isn't trustworthy.
I am doing that for quite a time now.
But even if pacman tells me the system is up to date, Discover keeps informing me about available updates which becomes annoying...
My question is now:
Why is that? I'd think Discover is kind of based on pacman or from where does it retrieve its information?
Is Discover definitely wrong, when pacman claims the system is up to date? Should I run the updates via Discover or should I really permanently ignore it?
Thanks!
Uninstall Discover?
When the native package manager and some 'random' 3rd party package manager differ, I'd always trust the native one.
Are the updates Discover sees Flatpak updates? Those are not handled by pacman.
(05-15-2023, 04:57 PM)Kevin Kofler Wrote: Are the updates Discover sees Flatpak updates? Those are not handled by pacman.
Yes, indeed. A flatpak update solved it.
I'm a bit embarrassed now.
Should I delete this or let it stay?
You already marked it "solved", that should be sufficient.
  Discover - "He's dead, Jim" jojuma 7 2,784 03-06-2023, 08:11 PM
Last Post: rocket2nfinity
  Can't install software via Discover or Terminal Kimberley van Buyten 2 1,572 06-10-2022, 02:13 AM
Last Post: shulamy
  Keyboard case stopped working on pacman update rotwang 5 3,177 05-07-2022, 09:17 PM
Last Post: rotwang
  Discover crashing (terminal output included). allworlds 1 1,386 05-05-2022, 06:46 AM
Last Post: allworlds
  Pacman vs. Discover jojuma 3 2,891 11-30-2021, 10:48 AM
Last Post: ryo
  Discover Error every boot pmprog 0 1,115 11-01-2021, 03:55 AM
Last Post: pmprog
  Ensure Up To Date - Manjaro Plasma Discover Package Manager Sources Linux2thabone 0 1,566 05-05-2021, 11:15 AM
Last Post: Linux2thabone
