Chatty -- no response after install
After seeing info on MMS success with chatty, I installed it with pacman.  I am running manjari-plasma beta8.
Installing chatty left a desktop icon called chats.  Starting chats gives a screen that says "start chatting".  Nothing happens after clicking everywhere.
The menu on chats opens up with choices that include preferences.  Clicking preferences does nothing.  Clicking all the other menu options also does nothing.
Any trick to how people are getting chatty going.  It is supposed to get MMS messages as well as SMS messages.  Does not even find contacts as far as I can see.
Any help, please.      Thanks,     tom kosvic
(12-11-2021, 09:55 AM)tckosvic Wrote: After seeing info on MMS success with chatty, I installed it with pacman.  I am running manjari-plasma beta8.
I also started chatty from a terminal to see if any error messages showed up.  An inactive chatty started up and there were no error messages.  Still no activity on chatty gui
  Can't install Manjaro thorensjubilee 1 1,015 02-09-2023, 08:17 AM
Last Post: thorensjubilee
  How to install iptables extensions? I get "Extension owner revision 0 not supported" anon4 0 2,135 08-27-2022, 12:19 PM
Last Post: anon4
  Can't install software via Discover or Terminal Kimberley van Buyten 2 1,561 06-10-2022, 02:13 AM
Last Post: shulamy
  After fresh install outbound phone calls not working. tckosvic 2 2,351 11-10-2021, 10:45 AM
Last Post: tckosvic
  Chatty SMS Backup/Restore d0n601 1 1,802 08-05-2021, 03:49 PM
Last Post: d0n601
  Chatty history disappeared after update tomoqv 0 1,139 07-24-2021, 04:34 AM
Last Post: tomoqv
  How do you install VPN so you can set up a config file, tor, signal and disk encrypt? temp0rary 5 3,918 05-30-2021, 08:14 PM
Last Post: temp0rary
  Can i install 16 different distros apart from the default manjaro? temp0rary 4 3,914 05-28-2021, 03:55 PM
  Manjaro Original Install + Phosh & Plasma on Multiboot - All Fracked After Upgrades Diagon 0 1,571 01-16-2021, 02:45 AM
Last Post: Diagon
  Install Anbox on Manjaro plasma-mobile help paju1986 11 18,070 11-21-2020, 12:35 AM
Last Post: hiimtye
