After fresh install outbound phone calls not working.
All expected things were working fine with pinephone.  A pacman update borked my pinephone and it wouldn't boot.  I installed fresh current img to phone main memory (not sd card) as below:.
"Manjaro-ARM-plasma-mobile-pinephone-20111108.img.xz".  Install was uneventful.  I did a pacman system update after the flash install that added some items.
I use a Consumer Cellular sim card.  Worked fine in past 6 months.
Testing of the new install shows that I can text outward,  receive texts inward.  Incoming voice calls are received.
Outbound calls, however, do not work.  PhoneBook and Phone app both say " Unable to make a call at this moment".   But this has been hours and is not a temporary Consumer Cellular system problem as I have an android phone working with the same carrier.
My sim card data shows in Settings -> Cellular Networks -> Sim card and data looks right.
Never had a phone problem (lots of others) before.  Any ideas, anyone?
I may reinstall the older img file where all was working if I can't get a fix going to see if something got gliched in update.
Thanks,  tom kosvic
(11-09-2021, 07:19 PM)tckosvic Wrote: "Manjaro-ARM-plasma-mobile-pinephone-20111108.img.xz".  Install was uneventful.  I did a pacman system update after the flash install that added some items...
So you installed a daily build. If you want something more stable, then I'd recommend to use a beta version and stay at this by updating it with pacman. The latest beta version is Release Beta 8 and it is here:
https://github.com/manjaro-pinephone/pla.../tag/beta8
acrux,
you suspected right.  I installed beta8 version and outbound calling works.  I checked and all texting and voice messaging is working.
Should I report my observation somewhere so others can avoid this problem and not devote a lot of time to it?  If so, point me.
thanks,     tom kosvic
  New phone, KDE desktop settings reset on reboot zzb0 2 1,823 10-15-2023, 10:19 PM
  How to create folders and re-org my phone desktop? A better "Image Viewer" app? nbh 0 586 09-24-2023, 05:18 PM
Last Post: nbh
  Calls/Texts and External Monitor gregb49 0 725 06-30-2023, 11:38 AM
Last Post: gregb49
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,653 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Internal Microphone issue during calls Viktor 6 2,641 03-31-2023, 08:58 AM
Last Post: Viktor
  Can't install Manjaro thorensjubilee 1 1,060 02-09-2023, 08:17 AM
  How to install iptables extensions? I get "Extension owner revision 0 not supported" anon4 0 2,197 08-27-2022, 12:19 PM
Last Post: anon4
  New issue with phone calls kmsgli 13 6,929 08-15-2022, 01:45 PM
Last Post: Gon
  Can't install software via Discover or Terminal Kimberley van Buyten 2 1,604 06-10-2022, 02:13 AM
Last Post: shulamy
  Keyboard case stopped working on pacman update rotwang 5 3,230 05-07-2022, 09:17 PM
Last Post: rotwang
