rock64-debian-mrfixit-190531.img.xz : missing /usr/lib/dri/rockchip_dri.so
Hello !
I have a V3 Rock64. No PSU or HDMI issues : i have XU4, RPI-1, RPI-2, BPI-M5 without problems.
- rock64-debian-mrfixit-190531.img.xz >> SD Card  :  it lags very much, when moving windows with LXDE.
- rock64-debian-mrfixit-190531.img.xz >> mmc Card (Foresee 16 Go) : i can't start X, xorg doesn't find /usr/lib/dri/rockchip_dri.so. Can't find this file on my disk.
- Armbian >> black lines on screen when moving windows in XFCE.
- Armbian >> dashboard moving up an down quickly when i move some windows (ex : PCManFM, but not galculator (?))
- Slackware XFCE : works great, but no dependencies supported by this OS (?).
- Ubuntu : i don't want.
- FreeBSD .img for Rock64 doesn't boot.
What distros work on your V3 board, please ?
Undecided
(07-30-2021, 05:20 PM)popi Wrote: Hello !
Try use this https://github.com/armbian/build/blob/ma.../xfwm4.xml settings for WM. Copy over in your home directory config/xfce4/xfconf/xfce-perchannel-xml/xfwm4.xml and try again. Or build image from sources.
(07-31-2021, 04:23 AM)igorp Wrote: Try use this https://github.com/armbian/build/blob/ma.../xfwm4.xml settings for WM. Copy over in your home directory config/xfce4/xfconf/xfce-perchannel-xml/xfwm4.xml and try again. Or build image from sources.
Thank you Igorp for your help  Blush
No luck, the black lines are still here, even after having changed the xfwm4.xml file.
This makes windows moving without showing inside, but those black lines..are still here  Angry coming from GPU/or driver (?).
No hope for this board : i have tested DietPi : it shows me on boot "5v error from gpio" messages.
Only slackware XFCE works good... for the moment.
Oups ! The Slackware doesn't boot from mmc, than i bought specialy for it  Dodgy
Cool : i have "NO OS" working for my Rock64 V3. Happy.
Undecided
How have you confirmed that you have no physical HDMI issues. I assume you have quality HDMI cables and no shorting at the HDMI headers on the board. I bought 5 Rock64 v2 boards and have confirmed that 2 of them have faulty ethernet sockets and 1 has a faulty USB2 socket possibly down to poor soldering. If you have any warranty left on the board I'd return it now.
I am pretty sure Armbian works on Rock64, even there is no official support. But you have to build it from sources - there were some important fixed added lately.
  How to update/compile Debian 12.5? Wizardknight 3 466 03-29-2024, 05:01 AM
Last Post: gedas07
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 160 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,377 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 345 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 631 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 622 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,494 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 191,133 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 605 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 659 05-27-2023, 06:11 AM
Last Post: Transportsicherung
