Pinebook Pro Won't Accept Charge
Huh  My Pinebook Pro just decided to quit accepting a charge.  The wall wart is putting out 5+ VDC, but the battery doesn't charge and now is totally dead.  I do not have a USB cable and don't really want to throw good money after bad.  Is there something I can do myself to remedy this?  Can I ship it back to Pine64 for service?  Or am I SOL?
Thanks in advance for your ideas.
I see that usbC cables are starting to show up in dollar stores,,
not at all ideal for charging, but only a dollar experiment.
Do try it both ways,, ie "C" end flipped,,,, if it works, get a better one
You don't want to spend much, so I won't recommend anything else
(and don't be in a rush, give it a hour, sometimes a dead battery takes a while)
Thanks, wdt, for your reply.  I'm a total noob.  I'll look up USB C cables online just to see what you're talking about.  How does the cable hook up to the PBP?  Does it backfeed into the USB C port then?  Also, what did you mean about try it both ways?  I totally agree this is worth trying.  Much appreciated!
I bought several usb-c cables at the dollar store (one us dollar each) and they all worked fine. I also bought one at the corner gas station for $4.99 which also works fine. With usb-c it's the same as charging a phone.
Cheers!
Online will usually be a bit more money, look for the word charging, so maybe
the wires are a bit thicker,, a standard cable, "C" at one end, "A" at the other
The C end can be plugged in 2 different ways, label up or label down
Sometimes it makes a difference, sometimes not. If it is working, the red led will light
You will have to find (or buy) your most powerful charger, 2.4A is usual maximum
Obviously, for a test, OR overnight, you can use one with less amperage, try for 1A minimum
A pc, the usb3 port supplies 900 mA, usb2 gives 500mA
BTW, the pbp usbC port is NOT smart, so don't need to get fancy cable or PD/QC charger
Do try to get a cable that is thick, there are 10 wires in it after all
(10-14-2020, 09:17 PM)rempfer Wrote: Huh  My Pinebook Pro just decided to quit accepting a charge.  The wall wart is putting out 5+ VDC, but the battery doesn't charge and now is totally dead.  I do not have a USB cable and don't really want to throw good money after bad.  Is there something I can do myself to remedy this?  Can I ship it back to Pine64 for service?  Or am I SOL?
Before sending it back I'd try opening it up and unplugging the battery, leaving it 30 seconds then plugging it back in. My pinebook stopped charging a while after receipt, any time I plugged in a charger it got stuck in a loop of trying to charge then giving up and this solved it.
The USB-C cable did start charging the PBP and then, after that experiment, the AC power supply resumed charging as well.
Thank you everyone!
  Pinebook Pro Initial Impressions kunger 443 592,868 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,331 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 415 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 315 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 303 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 240 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 693 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 775 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,670 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,285 12-15-2023, 02:11 PM
