OBS Studio or alternative on Pinebook Pro?
Is there any distro that will run OBS Studio on the Pinebook Pro? If not, any alternative?
(07-11-2020, 12:43 PM)charlespine Wrote: Is there any distro that will run OBS Studio on the Pinebook Pro? If not, any alternative?
OBS should be in the standard repos for Debian.
https://wiki.debian.org/obs-studio
I am partial to danielt's unofficial Debian Installer thread - with an installer for correct debootstrap of 64-bit. His installer - on git - works for 64/32, Buster (Stable)/Bullseye(Unstable)/Sid(Experimental) - depending on tweaks to the script files, and even allows for encrypted LUKS rootfs.
https://forum.pine64.org/showthread.php?tid=8487
If you are more comfortable with the Ubuntu packaging, OBS is also in the Ubuntu repos and a guide for that is here:
https://tecrobust.com/how-to-install-obs...20-04-lts/
To install 64-bit Ubuntu on the PBP, Syonyk wrote a good, complete guide here:
https://forum.pine64.org/showthread.php?tid=10279
Both of these alternatives will give you a pretty standard Linux experience with some kind of Gnome environment, largely comparable to their Intel-hosted brethren - with some restraints and constrictions due to platform differences (Appimage packages usually don't run, Netflix/Amazon restricted content unavailable for 64-bit, without tweaks, etc.).
— Jeremiah Cornelius
I believe I tried OBS on those distro’s. After installing and running OBS, I received an error message mention that it couldn't find a compatible GPU. So curious if anybody has OBS working...especially the virtualcam filter. I'm looking for good solutions for green screen videos.
Access to the VPU and GPU is still work in progress.
https://forum.pine64.org/showthread.php?tid=9171
I use this command
LIBGL_ALWAYS_SOFTWARE=1 obs
https://obsproject.com/forum/threads/fai...ost-416057
  Pinebook Pro Initial Impressions kunger 443 590,600 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,308 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 406 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 308 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 295 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 230 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 681 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 755 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,628 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,248 12-15-2023, 02:11 PM
