Power consumption and suspend to ram
#31
It took a few minutes to "puzzle out" what has happened here
When you did install of bsp uboot, it does 2 things, put uboot files in /boot for you to dd,
AND change extlinux,conf,, wrongly, the root= statement is now wrong (on emmc), not on SD
boot flow, with this mixed up boot, uboot (emmc) -> extlinux.conf (SD) ->rootfs (emmc)
so... edit extlinux.conf (emmc) to have correct root=
sudo blkid will show all
And, BTW, 5.9 cannot do suspend 3, s3, s2mem, suspend to mem
(what version? uname -r or ls /lib/modules/)
If you want this, have to downgrade to 5.8, if it is in /var/cache/pacman/pkgs/ is a lot easier (pacman -U something)
Be sure that the boot is sorted first, of course
#32
(11-30-2020, 12:47 PM)wdt Wrote: It took a few minutes to "puzzle out" what has happened here
Thank you very much for looking into this.
You are right, the extlinux.conf had a wrong entry under root=, so I modified it and the emmc now boots, but the screen is still blank.
I will boot from a clean SD and rewrite the default uboot on the emmc. So I will stick to it, as I do not know how to downgrade to 5.8. I wanted the S3 to work, because as of now leaving the PBP to sleep consumes the battery fast.
Is there any easy way to enable the S3?
Cheers!
#33
Cheers!
For whatever reson u-boot.itb was not present in the /boot. I copied it there from the SD card and now I am able to boot from the emmc.
Thank you very much!
Now I just need to see how can I resolve the S3 activation. Smile
#34
ls -l /var/cache/pacman/pkgs/linux-* ,,, is there linux-pinbookpro-5.8.14...,,, then pacman -U that package
otherwise, install downgrade, may (likely) have to enable arch repo,, AUR is what it is called
5.7.19 also works (for mem sleep)
But reading your post again, I am a bit confused,, bsp uboot has 3 files,
idbloader.img,,uboot.img,,trust.img. When you see u-boot.itb, that is mainline, has trust within it
  Lockable-until-power-cycle persistent storage Melab 0 820 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 924 07-20-2023, 11:06 PM
Last Post: papable
  When does Pinebook Pro power LED go on? Bram 0 691 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,366 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 2,440 09-09-2022, 08:13 PM
  high battery drain on suspend/poweroff wiz 5 5,268 02-10-2022, 11:52 AM
  Replacement Power Cord recommendation? nathanielwheeler 3 3,427 01-23-2021, 06:43 PM
  power light blinking during charge when pbpro is off Idaho 0 1,862 01-04-2021, 10:53 AM
Last Post: Idaho
  Taming the power switch? ab1jx 4 5,018 11-30-2020, 10:57 PM
Last Post: rimaille
Exclamation Seemingly lost power permanently now /cry jimsurvak 2 3,177 11-16-2020, 06:22 PM
Last Post: jimsurvak
