Private Internet Access VPN on Pinebook Pro
Greetings,
Do any of you use VPN's on your pinebook pro?  I tried installing PrivateInternetAccess on mine, but it doesn't want to run.  I was wondering if anybody here had any success with it, or could point me to a suitable alternative.  Also, how would I go about uninstalling it, I'm still presently a noob...
Thanks!
I use wireguard.
What problems do you have ? Installing a client ?
(10-23-2020, 11:23 AM)as400 Wrote: I use wireguard.
Since I had a PIA subscription, I wanted to try and see if it would work on the Pinebook Pro.  I followed the instructions on their website, it completed the installation, but when I try to run it, I get a notification saying "Launching Private Internet Access (Failed) execvp:Exec format error".  It was a shot in the dark, although it does run on my desktop with Linux Mint.  Anyway, at this point, I'd like to get it to work or learn how to uninstall it AND find a VPN that does work on the Pinebook Pro.  I'll check out wireguard, thank you for letting me know about it!
Wait, if you get "format error" then it means you were trying to run x86 binaries while your Pinebook Pro is ARM based machine.
Which means it's not compatible with either Linux Mint or anything that is designated for x86 computers.
(10-23-2020, 11:54 AM)as400 Wrote: Wait, if you get "format error" then it means you were trying to run x86 binaries while your Pinebook Pro is ARM based machine.
Darn... well, thank you for taking the time to provide me with this information.
Don't loose faith.
There are a lot of VPN services you can use Smile For sure.
(10-23-2020, 12:16 PM)as400 Wrote: Don't loose faith.
Thank you! I'm optimistic.  I like your avatar btw, the virus from "Il etait une fois la vie", that's nostalgic, I watched that show all the time, when I was a kid lol..
I dunno if it'll help in your case but this is how I set up my express vpn on the pbp :
http://imgur.com/gallery/8RprIyS
Maybe you can follow similar steps to set up yours.
Sent from my OnePlus 7 Pro using Tapatalk
Bastafari,
I am looking to set up my expressvpn on my new pinebook pro running the pre loaded manjaro os.  I'd be very interested in how you achieved it, but the link you provided doesn't seem to be working for me.  Could you share the process in some other way?  Many thanks in advance!
(10-25-2020, 10:14 AM)silverine Wrote: Bastafari,
Click the hyper link in the post by me before you. It takes you to a guide I made. It may or may not apply to you but give a shot.
  About new OS over pinebook debian voje12 1 60 06-07-2024, 11:54 AM
  Pinebook Pro Initial Impressions kunger 443 605,658 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,476 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 553 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 423 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 416 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 342 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 848 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 930 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 8,031 12-17-2023, 09:29 PM
Last Post: insideau786
