Default Theme
Hi all,
I tried the dark theme by:
gsettings set org.gnome.desktop.interface gtk-theme “Adwaita-dark”
How to get back to the default one?
PBP ISO / Debian Bullseye (unofficial installer)
Just remove -dark on the same command line
(06-25-2020, 01:11 PM)rico Wrote: Just remove -dark on the same command line
I am sorry it doesn't work
Have a look at:
gsettings help reset
Have a look at:
It works, thanks Smile
  4G data on default startup / boot dcinoz 1 925 04-29-2023, 11:24 PM
Last Post: dcinoz
  Bogus default gateway keeps appearing Zebulon Walton 7 2,470 02-25-2023, 09:48 PM
  Dark theme (on Mobian)? TRS-80 10 7,890 08-10-2022, 07:49 PM
Last Post: jurop88
  Change default program for a file type 3x5co 1 1,836 09-01-2021, 05:26 PM
  Default SMS app send button off screen in vertical orientation motox6 0 1,291 05-22-2021, 02:55 PM
Last Post: motox6
  Make 'terminal' on-screen keyboard the default 3x5co 0 1,872 12-27-2020, 05:11 PM
Last Post: 3x5co
  ssh not enabled, by default? RodMyers 6 6,191 10-02-2020, 07:35 AM
Last Post: LinAdmin2
  sudo / lock screen password keeps resetting to default ergo owl 6 7,085 09-04-2020, 06:07 AM
Last Post: ergo owl
  How to change the minimum password length when changing from default passwords arturo2bodegas 3 4,687 07-18-2020, 01:51 PM
Last Post: arturo2bodegas
