RockPro64 as Synology NAS alternative!?
Hello all here,
I am new with Pine64, had a chat lately with a friend regarding NAS and it's power consumption.
I am thinking about switching from my Synology 713+ NAS to a Pine64 RockPro64-4GB NAS.
My 713+ Synology uses about 40Watt's constant incl. 2 WD RED 3TB HDD's (in RAID).
Seems that the Synolofy HDD's don't fall asleep after some time
Can you guys tell me about your the RockPro64 power consumption as a NAS with 2 HDD's ?
Started reading here:
https://wiki.pine64.org/index.php/NASCase
Some more questions:
You can connect only one fan on the PCB, in the NAS-case or on the CPU, what do you advise? Or can it run only with the largest heatsink?
As OS OpenMediaVault is suggested, this is best to use or do you have an alternative?
On the Synology (which I only use as Storage and hosting photo's) I use the programm "Photostation", what do you guys prefer to use?
Between my two Synology's I use "Hyper Backup" to sync from one to another.
I believe "Hyper Backup" is a Rsync tool?
Is it possible to Sync from OpenMediaVault to `Synology #2 ?
Thx!
Gr. Hemertje
  • 8,4 - 9,3 Watt mit 2 Stück 2,5 Zoll HDD (hdparm inactive)
  • 5,6 Watt mit 2 Stück 2,5 Zoll HDD (hdparm aktive)
With two 3,5 Zoll HDDs 25 - 30W
2. You don't need an fan, when you only use your NAS as data storage.
3. I am using only debian for my NAS and NFS for LAN. Backups i do with rsync.
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(12-21-2019, 12:40 PM)Bullet64 Wrote: Hello,
1.
Hello Bullet64,
Thx for your reply, Danke fur ihnen antword
Grussen aus Holland...
Frank, what do you use as "photostation" ?
WD RED 3TB 3,5"
HDDhttps://storagereview.com/western_digital_red_nas_hard_drive_review_wd30efrx
Specs: Power 2TB/3TB: read/write 4.4W, idle 4.1W, standby/sleep .6W
Do your HDD's in combination with the Pine64 NAS get to sleep when not used?
@hemertje
I use nextcloud for my photos. Nextcloud don't run on my NAS, nextcloud runs on an hosted server. I only save backups on my NAS.
3. RockPro64 v2.1
  Installing Wifi drive for the RockPro64 John45595 0 607 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 1,176 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 909 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 5,123 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 1,139 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,714 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 2,418 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 3,474 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,254 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 2,290 10-21-2022, 07:44 AM
Last Post: rapier1
