Pinebook Pro 'xtreme'
 Now that the Pinebook Pro is being perfected,
   How about a :   'Pinebook Pro Extreme'   ?
  1) a 19" Wide screen
  2) Maybe dual batteries
  3) Able to boot from the NVMe
  4) Larger Speakers that point up from the palmrest
   That would likely attract a lot of attention,
        Of Course it would cost a bit More,,,
   but it likely attract even more potential high end customers.
                   Just a thought  ?
***     "More than a utility device,  an entertainment center"  !    (?)   ***
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
You lost me at 19 inch screen haha. If there were to be an extreme version, I'd like to see newer and more powerful arm core being used in a 4 + 4 big/little configuration, and a GPU with around 3x the performance for fluid 4k 60p video rendering. Reusing the current PBP chassis would be fine with me. Increased battery life is rarely a bad thing.
The PBP is already High Def.,  the screen at 14" leaves it with rather small print for 'some of us'.
You can plug it into your TV if you want to take full advantage of the existing HD video output.
*   Though I would not throw out the idea of a 'hotter' gpu.
*  There are 'hotter' arm cpu's available that would not break the bank.
*  But,  keeping with the spirit of the Pinebook Pro,
*   I would think the price of a 'Pinebook Pro Extreme' would still be 'priced very competitively'
*  SO,  Not  'The hottest' everything,  Just,  mostly Extremely LARGE....
**  BUT  That is MY  pipe dream.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
If that's what you're after, perhaps "Pinebook Pro Plus" would be a better name.
And still very portable
You may be correct on the name, but Extreme does sound more 'Catchy' ?
I DO like everything about this little PBP, just would like it even more with a bigger screen
* and larger louder speakers
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Personally, I'm not convinced that a large PBP (from this generation) makes much sense. Reason being, large laptops are usually mobile workstations - and the PBP simply doesn't have the power to be a mobile workstation for video/photo-editing, 3D design/ processing, etc., so I feel like the 13-14in ultra-mobile form-factor suits it and its characteristics best.
Also, hope you don't mind but moving thread to general in Pinebook Pro sub-forum, where I feel this thread belongs.
OK sure, thank you
Though I think it could possibly be considered an entertainment device without needing a bunch of power
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
I'd rather see a replacement CPU board made available when the RK3588 comes out. Its a 4 + 4 BIG.little config, with lower power and other improvements. If the "shell" of the Pinebook Pro tends to hold up to reasonable usage, then some people may opt to upgrade it's guts. Others might buy the mythical "Pinebook Pro+".
When I looked at the original Pinebooks ayear ago, they just missed what I was looking for. Like 3 x USB. Or larger SSDs / second drive. Pinebook Pro hit all those and more, so I bought it.
Plus, instead of a monster laptop, I'd prefer to see the next generation a bit more hardware hackable. In that regard I can help, being a former Assistant Design Engineer for embedded computers. Like external access to internal switches, using a paper clip or such. And expansion pads where someone can solder either a connector or cable for internal extras.
Arwen Evenstar
Princess of Rivendale
+1 on the rk3588 mainboard train here. The 14" form-factor and weight/screen are perfect for me but I'd absolutely get behind a more powerful SoC baseboard.
If I had to pick two things I'd like to see in a premium PBP they'd be a more powerful baseboard and at least the option to spend extra money for a premium touchpad/chassis/keyboard with real multi-touch and better responsiveness. Given the option I'd happily drop decent money for both of those things even as DIY replacement parts.
+1 on the RK3588 replacement board for existing PBP. Such thing should be much faster since the big cores are Cortex A76.
  About new OS over pinebook debian voje12 1 52 Yesterday, 11:54 AM
  Pinebook Pro Initial Impressions kunger 443 605,508 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,474 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 552 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 423 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 416 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 342 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 846 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 928 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 8,027 12-17-2023, 09:29 PM
Last Post: insideau786
