slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#21
(04-29-2018, 12:06 AM)mara Wrote:
(04-28-2018, 05:03 PM)valarauca Wrote: Hello could you host a torrent?
Your webserver is incredibly slow (and spotty) to download from. I'll happily assist in seeding.
ok, http://dl.fail.pp.ua/slackware/images/ro...cy.torrent
HTTP 403 ?
Can confirm, forbidden here in Oz also Wink
HTTP 403 ?
fix
(04-29-2018, 03:21 AM)mara Wrote: fix
Confirmed. I have a rtorrent session listening and waiting to seed in a VPS over in the Netherlands... although it's not doing much atm...
fix connection
(04-29-2018, 06:50 AM)mara Wrote: fix connection
The slack-Xfce 4.4.126 image works on micro SD at home without modification
On the other hand it crashes after a few minutes
update images:
slack-current-aarch64-miniroot_08May18-4.4.126-rock64-build-20180508.img.tar.xz
slack-current-aarch64-xfce_08May18-4.4.126-rock64-build-20180508.img.tar.xz
(05-08-2018, 02:39 PM)mara Wrote: update images:
Hello
Are people managed to run the slack... Xfce image?
I no, even with a lot of attempts.... different micro SD cards and a lot of reboot.
Yet I think it had to be tested before!!! I do not know where the problem comes from?
Thank you for your answers
Hello
hi
I tested the download from sdcard
http://p.fail.pp.ua/Wz7ECz8O
Hello
hi
Hello Mara,
I deleted on the rock64 the Uboot-SPI-flash image I had installed before
and now the Slackware system starts up correctly on the USB micro and is stable at the moment.
Thank you for your previous Help
Hello
hi
Hello Mara,
Sorry
You had to understand on the "Micro SD card"
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 228 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,478 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 404 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 726 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 728 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 9,089 10-12-2023, 05:14 PM
Last Post: tpaul
  arch rock64 does not boot nemnob 0 659 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 713 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 35,842 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 1,006 08-29-2022, 01:22 PM
Last Post: ramprasad
