GPIO and SPI
#21
Is there still work being done on porting WiringPi to the Pine64 platform? I've tried the code from the pfeerick link but that does not work.
https://github.com/pfeerick/wiringPi-Pine64
One thing I found was that the /proc/cpuinfo file does not have a 'Revision" line thus running an example bombs out. I tried to create my own cpuino file add a Revision line in the cpinfo file and change the line in the source code to reference this but it still does not recognize the Revision. I ended up grabbing a more current version of WiringPi and it has more Pi_MODEL entries in WiringPi.h so I tried to add an entry in there. Also, I had to add a Hardware entry for "sun50iw1p1" and was able to get something to sort of run but I am not sure it is correct.
Is there a working version of WiringPi for the Pine64 board?
  RPi.GPIO python module for Pine A64/A64+ aquilegia 99 217,966 12-15-2025, 07:42 AM
Last Post: freidepiter
  fm transmitter with gpio weasel18 2 8,131 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 5,982 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 17,782 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 17,332 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 18,099 01-24-2019, 03:36 AM
Last Post: Fifth
Question GPIO shockr 7 22,448 03-11-2018, 01:52 AM
Last Post: jomoengineer
  Read GPIO problem shworker 14 33,955 08-17-2017, 01:21 PM
Last Post: martinayotte
  GPIO fiq capability joseph 3 9,803 11-10-2016, 06:07 PM
Last Post: joseph
  RPI2-GPIO mus1c 6 15,410 09-22-2016, 05:28 AM
Last Post: mus1c
