RPi.GPIO python module for Pine A64/A64+
I just ported RPi.GPIO python module for Pine A64/A64+.
You can download the package from https://github.com/swkim01/RPi.GPIO-PineA64.
Thank to joey for gpio pin information.
However, the event detect function was not operated yet.
I guess the kernel's gpio driver has to be modified to enable gpio interrupts.
I tried to install it. During the installation, it gived to me an error:
"Python.h cannot found file or directory"
I am sure to have Python installed, because if I write "python" in terminal, it returns me the version
You need to have also "python-dev" package
(05-04-2016, 08:29 AM)martinayotte Wrote: You need to have also "python-dev" package
Thanks for help! I have already tried it and I have switched on a LED. [emoji6]
Does this RPi.GPIO also support DMA access? I want high speed access so I can control a Neopixel light bar.
Just looked at the Readme... No PMW access.... Drat.... OK. I will have to wait on info for this because the DMA access is for the PMW.
Maybe I can get my hands on the PMW/DMA version of the RPi.GPIO and see what I can do to have it work on the Pine.
Thank you for the port though. This might help me figure a few things out.
(05-26-2016, 03:21 PM)PallStar Wrote: Maybe I can get my hands on the PMW/DMA version of the RPi.GPIO and see what I can do to have it work on the Pine.
For reference, I am looking at this code. Time to get my hands dirty and learn the code.
Penfold42's PRi PWM port for RPi.
(04-22-2016, 12:39 AM)aquilegia Wrote: I just ported RPi.GPIO python module for Pine A64/A64+.
Confirmed! works like a charm - thanks mate
Great work!! I'll try it as soon ad possible
Using this ported software, could I control a LedBorg that I used on my raspberry pi?
Hi, i've installed this library but i'm not able to turn on a led. This is my code from python shell:
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setup(20, GPIO.OUT) //i don't know if this is the right number for the pin 38
GPIO.output(20, True)
What i'm wrong?
(06-10-2016, 04:06 AM)igna09 Wrote: Hi, i've installed this library but i'm not able to turn on a led. This is my code from python shell:
What i'm wrong?
The code seems correct. Some pin cannot be selected (for example 1, 2...). Try with pin 3 to be sure.
  fm transmitter with gpio weasel18 2 7,865 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 5,802 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 17,269 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 16,836 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 17,623 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 47,174 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 21,870 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 32,999 08-17-2017, 01:21 PM
Last Post: martinayotte
  Cross-wired Uart Ports between two Pine Boards via Cat5 Cable MarkHaysHarris777 10 24,603 11-20-2016, 04:17 AM
Last Post: pfeerick
  GPIO fiq capability joseph 3 9,500 11-10-2016, 06:07 PM
Last Post: joseph
