How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)?
Using armbian bionic mainline kernel on A64-v1.1 board
Linux pine64 4.19.38-sunxi64 #5.83 SMP Fri May 3 21:02:31 CEST 2019 aarch64 aarch64 aarch64 GNU/Linux
In RPI bionic could just set values in boot.txt.  Is this possible in armbian bionic mainline?
I know that one can use device tree overlays but can't find any examples specific to the A64.
Anyone have a dts file or otherwise know how to declare a pin as an interruptible input?  I've come across nothing in any A64 docs.
Looks like I tracked down an example dts file here
https://github.com/armbian/sunxi-DT-over...button.dts
here is more explanation of how to implment
https://docs.armbian.com/Hardware_Allwin...m-overlays
Still need to edit, compile and try it, but at least good example to go from
  RPi.GPIO python module for Pine A64/A64+ aquilegia 99 221,301 12-15-2025, 07:42 AM
Last Post: freidepiter
  fm transmitter with gpio weasel18 2 8,266 09-10-2019, 04:28 AM
Last Post: desai_amogh
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 18,050 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 17,611 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 18,339 01-24-2019, 03:36 AM
Last Post: Fifth
  +LTS/SOPINE +PINEBOOK configuring Euler Bus pin generate interrupt RANJITT76 0 4,039 01-10-2019, 02:45 AM
Last Post: RANJITT76
  GPIO and SPI SamR1 20 49,180 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 22,732 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 34,401 08-17-2017, 01:21 PM
Last Post: martinayotte
  GPIO fiq capability joseph 3 9,950 11-10-2016, 06:07 PM
Last Post: joseph
