GPIO fiq capability
Hello all,
I want to bind the FIQ to a GPIO pin input processing.  Is this functionality available on the Pine64?
I see definition of the pending request in drivers/irqchip/irq-sun4i.c,
#define SUN4I_IRQ_FIQ_PENDING_REG(x)    (0x20 + 0x4 * x)
but no reference or apparent support in the module.
Should I be looking elsewhere?
Thank you,   Joe
Of course its supported ( as it is on any arm device ) but you're going to be hard-pressed to find Allwinner documenting it anywhere.
(11-09-2016, 05:45 PM)joseph Wrote: Hello all,
Thank you,   Joe
Hi Joe, try using Duck Duck Go as your search engine. Google gives no return with   SUN4I_IRQ_FIQ   but Duck returns over 30.
https://duckduckgo.com/?q=SUN4I_IRQ_FIQ&t=hq&ia=web
I hope this will be of use to you. sq
Marcus, squid4t2 - I appreciate your responses.
squid4t2, thank you for the duckduckgo suggestion. Definitely more to look through.
All the best, Joe
  RPi.GPIO python module for Pine A64/A64+ aquilegia 99 221,673 12-15-2025, 07:42 AM
Last Post: freidepiter
  fm transmitter with gpio weasel18 2 8,276 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 6,088 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 18,078 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 17,640 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 18,357 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 49,255 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 22,767 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 34,507 08-17-2017, 01:21 PM
Last Post: martinayotte
  RPI2-GPIO mus1c 6 15,655 09-22-2016, 05:28 AM
Last Post: mus1c
