Home Assistant Supervisor for rock64
Hi everyone, I'm Paolo and I'm Italian and sorry for my English, I wanted to install Home Assistant Supervisor on the rock64 with 4gb of ram but all my attempts failed; could someone kindly help me figure out which version of linux to install and what other steps I need to take to install it? i tried to use Armbian_21.05.1_Rock64_buster_current_5.10.35.img but then when i proceed with this:
1) sudo apt-get update && sudo apt-get upgrade -y
2) sudo apt-get install jq wget curl avahi-daemon udisks2 libglib2.0-bin network-manager dbus apparmor -y
3) sudo apt --fix-broken install
4) sudo reboot
5) curl -fsSL get.docker.com | sh
6) wget https://github.com/home-assistant/os-age..._armv7.deb
here is the error ....
7) sudo dpkg -i os-agent_1.2.2_linux_armv7.deb
thanks to those who can help me  Smile
Hi Karbon,
Try DietPi and install Home Assistance from there.
Paolo,
You didn't actually post the error, mate! Wink
Also, I'm pretty sure that Home Assistant is available in armbian-config, if so that will likely be the easiest way. Although I am not sure if that includes the Supervisor component, or if that is a separate thing.
(02-22-2022, 01:20 PM)helpmerock Wrote: Try DietPi and install Home Assistance from there.
I can't swear to it, but I want to say that DietPi is actually downstream from Armbian on Rock64.
Cheers,
TRS-80
Protocols, not Platforms
(02-22-2022, 01:20 PM)helpmerock Wrote: Hi Karbon,
Hello installed DietPi and performed all the steps and Home Assistant seems to be installed correctly, but does not start at 192.168.1.9:8123
root@DietPi:~# sudo dpkg -i homeassistant-supervised.deb
Selezionato il pacchetto homeassistant-supervised non precedentemente selezionato.
(Lettura del database... 18943 file e directory attualmente installati.)
Preparativi per estrarre homeassistant-supervised.deb...
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
Viene aggiunto "deviazione di /etc/NetworkManager/NetworkManager.conf in /etc/NetworkManager/NetworkManager.conf.real da homeassistant-supervised"
Viene aggiunto "deviazione di /etc/NetworkManager/system-connections/default in /etc/NetworkManager/system-connections/default.real da homeassistant-supervised"
Viene aggiunto "deviazione di /etc/docker/daemon.json in /etc/docker/daemon.json.real da homeassistant-supervised"
Viene aggiunto "deviazione di /etc/network/interfaces in /etc/network/interfaces.real da homeassistant-supervised"
Estrazione di homeassistant-supervised (1.1.0)...
Configurazione di homeassistant-supervised (1.1.0)...
[info] Restarting NetworkManager
[info] Restarting docker service
PING version.home-assistant.io (172.67.68.90) 56(84) bytes of data.
64 bytes from 172.67.68.90 (172.67.68.90): icmp_seq=1 ttl=55 time=20.8 ms
--- version.home-assistant.io ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 20.828/20.828/20.828/0.000 ms
[info] Install supervisor Docker container
[info] Install supervisor startup scripts
[info] Install AppArmor scripts
[info] Start Home Assistant Supervised
[info] Installing the 'ha' cli
[info] Within a few minutes you will be able to reach Home Assistant at:
[info] http://homeassistant.local:8123 or using the IP address of your
[info] machine: http://192.168.1.9:8123
root@DietPi:~#
after the command: sudo dpkg -i homeassistant-supervised.deb asks me to select the machine type, I tried with raspberry 3, which is the correct one for rock64?
[warn]
[warn]
root@DietPi:~#
cheers, up and running, with DietPi v8.1.2v
Hello everybody
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 203 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,445 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 385 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 697 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 678 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,850 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 194,869 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 639 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 689 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,946 12-07-2022, 08:22 PM
Last Post: luminosity7
