Changing Boot Order on the PineBook Pro
Hello, I searched for an answer but I'm not finding anything.  Apologies if this has been asked and answered already.
My Pinebook Pro boot order was behaving as expected for quite some time.  It was booting from the SD card when a bootable card was inserted, and then from the eMMC otherwise.
After flashing Ayufan's Chromium OS build to the eMMC, now for some reason the PBP always boots from the eMMC card unless I disable the hardware switch for it.  This effectively makes the eMMC worthless since it can't be re-enabled without rebooting, but then the boot happens from the eMMC (which is currently in a totally broken state and needs to be re-installed).  I've now got a real chicken and egg problem going here.
I had read that the boot order was fixed (possibly hardcoded) but given my experience here, I'm wondering how true that actually is.
Is there any way to change the boot order?  How can I restore it to factory settings?
It may be possible to re-enable the eMMC after you have both disabled it, and booted to an alternate source, like MicroSD card.
I've used similar instructions for my x86/x64 Media server's MicroSD card. Here is what I have;
Un-TESTED!!!! Use at your own risk. This is from the default Debian, but may
work on others.
While powered off, switch eMMC to disabled state. Then power on. If the user
is not fast enough with the switch to enabled state, the OS image on the SD card
won't see the eMMC. Thus, it may be needed to un-bind and re-bind the eMMC driver.
Note, it is still REQUIRED to enable the eMMC via the hardware switch. These
instruction below, MAY allow the OS to find it after boot.
The first 2 outputs may show nothing, which could happen if OS thinks the eMMC
does not exist. The 3rd command checks and sees if it's possible to unbind and bind.
Lines 4 & 5 are the real work. Though again, line 4 may not do anything if the device
is already un-bound.
# blockdev --getsize64 /dev/mmcblk1
125069950976
# readlink /sys/block/mmcblk1
../devices/platform/fe330000.sdhci/mmc_host/mmc1/mmc1:0001/block/mmcblk1
# ls /sys/bus/platform/drivers/sdhci-arasan
bind fe330000.sdhci uevent unbind
# echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/unbind
# echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/bind
Arwen Evenstar
Princess of Rivendale
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 7 10,918 10-05-2026, 12:42 PM
  Replacement battery for PineBook Pro DrYak 5 9,633 02-28-2026, 09:17 PM
  pinebook pro dixplays vertical stripes WEF 2 5,233 03-23-2025, 03:31 PM
Last Post: WEF
  Yet another new Pinebook keyboard problem MikoBob 3 5,825 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 5,012 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 5,082 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 4,043 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 240,219 09-13-2023, 03:43 AM
Last Post: k3dAR
  PineBook Pro dead ottahe 9 15,705 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 14,248 12-27-2022, 03:31 PM
Last Post: samtux
