[Debian] How to enter single user mode?
I am trying to enter single use mode.
The purpose is to move /var /usr and /home to a newly installed ssd.
I tried typing "init 1" and I got a black screen with a blinking cursor, no text input.
The same thing happens when I tried "systemctl isolate rescue.target".
Are there boot options to allow me to enter single user mode?
I could always boot from an sd card and do it from there, only I don't have one handy at the moment. Besides single user mode should work.
Yes, I would like to know how too
Just asking, were you in a vt or xterm?
I would not expect it to work in a xterm
You can use rsync, I made a copy of stock with rsync,,
dd the 1st 16M, fdisk to fix part table, make fs, mount
cd to part1 ,, rsync -a /boot .
cd part2 mkdir proc, dev, sys, run (empty directories, don't rsync)
rsync -a (all the rest, 1 at a time) . (rsync -a /bin . ,,, and so on)
To have X not active, reboot, don't login, change to vt, login there (as root)
You likely will have to manually do mount of nvme, and make a fstab
Single user mode is extremely crippled but try a search like https://duckduckgo.com/?q=linux+%22singl...fnt&ia=web
It's better I think to load up a spare bootable SD and boot from that, even using a USB reader, so you're up and running without your main devices mounted. Do what you need to do to them, shut down and pull out the SD, then boot up your normal way. In the old days you'd use a live cd for this.
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 19,036 06-26-2025, 09:20 PM
Last Post: reukiodo
  Official Debian support moonwalkers 64 124,248 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  Debian on Pinebook Pro u974615 7 12,541 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 12,432 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 23,597 09-07-2023, 09:38 PM
  Emergency Mode Boot Hotkey? jiacovelli 20 20,314 06-02-2023, 01:32 PM
  Enter disk description passphrase Galaxy9 1 3,029 01-14-2023, 02:49 PM
Last Post: fxc
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 4,952 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 5,968 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 6,595 10-19-2022, 03:09 AM
Last Post: alpopa
