Slackware (aarch64) on the Pinebook Pro
Hi Folks,
After purchasing a Pinebook Pro recently I was faced with the fact that there was no out-of-the-box Slackware (or derivative of thereof) installer available.
After spending some time interacting with forum user mara/sndwvs at LinuxQuestions ( https://www.linuxquestions.org/questions...?p=6093972 )
I managed to cross-compile (on x86_64) an installer file system image with his script that's available at https://gitlab.com/sndwvs/slackware_arm_build_kit
Unfortunately the installer image doesn't seem to work: it doesn't boot on Pinebook Pro for some reason.
What I see is that when the micro SD card is inserted, and the system powered on, the screen stays blank, and seemingly nothing happens.
How could I debug this boot-related problem? Do I need the serial cable to do that, or can it be debugged some other way too?
Thanks in advance!
Best Regards,
János
Hi Janos, any news?
Did you succeed and made your image booting?
I'm not that experienced in debugging such systems. But I'm curious if slack is possible.
Best regards
zedr0k
(02-28-2020, 11:33 AM)zedr0k Wrote: Hi Janos, any news?
Best regards
zedr0k
No, unfortunately. I haven't been able to make it boot with the slarm64 installer images.
(03-03-2020, 04:50 AM)wowbaggerHU Wrote: No, unfortunately. I haven't been able to make it boot with the slarm64 installer images.
Another update: The installer images look okay, but the different kernels are stuck during startup.
For more information please see: https://www.linuxquestions.org/questions...ost6099060
Best regards
zedr0k
We finally managed to create a working bootable image of the slarm64 installer. For details please see:
https://www.linuxquestions.org/questions...ost6099406
Hi Janos,
great news. I tried the image and it works fine.
Thank you. Good to have slack on the pinebook pro
Best regards
zedr0k
Awesome stuff! You should add this to the PBP Software Releases wiki page.
Yes, it is very nice, speedy, I started with slackware a long time ago
It is an IMMENSE amount of work to get X running, and imperfectly
Maybe a template? Thanks for your work
  Debian on Pinebook Pro u974615 7 995 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,565 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,135 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,206 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,568 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,225 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,247 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,478 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,579 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 659 07-13-2023, 05:21 PM
Last Post: owaspfap
