Eduroam Wifi Issues
Hey everybody,
I have the pinebook pro with the standard os that ships with it.
I have a strange problem. when I am at home, I can stay connected to wifi without really noticing any issues.
At work, I connect to Eduroam (https://en.wikipedia.org/wiki/Eduroam) and it works just fine for a few minutes. But then it starts to drop the connection -- sometimes it shows up as connected but  is actually not. I can then reconnect but keep having trouble until I reboot the machine.
I went through the suggestions on the pinebook pro wiki (https://wiki.pine64.org/index.php/Pinebo...iFi_issues) but nothing worked so far.
Has anyone else experience this problem?
Does anyone connect to Eduroam without any problem ?
Edit:
Have been at a different institute today and had no issues with Eduroam at all. So it seems to be a local issue.
Update:
Switched to Manjaro: Wifi issues with eduroam are still there. However, it seems to work fine when using a wifi-dongle.
Is there anything in the kernel log about the failure? e.g. run `sudo journalctl -f` in a terminal window and look for red or yellow messages about brcmf when the connection goes bad.
I can't join my school's WPA2 network because of a driver crash after authentication, but your problem sounds different. I'll try connecting to eduroam next time I'm on campus and see if it behaves the same way.
(02-11-2020, 10:29 AM)rillian Wrote: Is there anything in the kernel log about the failure? e.g. run `sudo journalctl -f` in a terminal window and look for red or yellow messages about brcmf when the connection goes bad.
Thanks for the suggestion. I did run `sudo journalctl -f` and  this is what it told me at the time the wifi dropped.
Feb 14 11:11:21 Debian-Desktop kernel: dhd_bus_devreset:  WLAN OFF DONE Feb 14 11:11:21 Debian-Desktop kernel: wifi_platform_set_power = 0 Feb 14 11:11:21 Debian-Desktop kernel: ======== PULL WL_REG_ON(-1) LOW! ======== Feb 14 11:11:21 Debian-Desktop kernel: [WLAN_RFKILL]: rockchip_wifi_power: 0 Feb 14 11:11:21 Debian-Desktop kernel: [WLAN_RFKILL]: wifi shut off power. Feb 14 11:11:21 Debian-Desktop kernel: wl_android_wifi_off out Feb 14 11:11:21 Debian-Desktop kernel: wl_ext_iapsta_dettach_netdev: ifidx=0 Feb 14 11:11:21 Debian-Desktop kernel: dhd_stop: Exit Feb 14 11:11:21 Debian-Desktop kernel: CFG80211-ERROR) wl_cfg80211_hang : In : chip crash eventing, reason=0x8001 Feb 14 11:11:21 Debian-Desktop dhcpcd[481]: wlan0: carrier lost Feb 14 11:11:21 Debian-Desktop dhclient[3808]: receive_packet failed on wlan0: Network is down Feb 14 11:11:21 Debian-Desktop wpa_supplicant[508]: wlan0: CTRL-EVENT-DISCONNECTED bssid=f0:5c:19:04:fe:62 reason=3 locally_generated=1 Feb 14 11:11:21 Debian-Desktop avahi-daemon[367]: Interface wlan0.IPv6 no longer relevant for mDNS. Feb 14 11:11:21 Debian-Desktop NetworkManager[414]: <info>  [1581675081.7918] device (wlan0): supplicant interface state: completed -> disabled Feb 14 11:11:21 Debian-Desktop avahi-daemon[367]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::c284:7dff:fe2e:be4e. Feb 14 11:11:21 Debian-Desktop avahi-daemon[367]: Interface wlan0.IPv4 no longer relevant for mDNS. Feb 14 11:11:21 Debian-Desktop avahi-daemon[367]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 194.171.31.227. Feb 14 11:11:21 Debian-Desktop avahi-daemon[367]: Withdrawing address record for fe80::c284:7dff:fe2e:be4e on wlan0. Feb 14 11:11:21 Debian-Desktop avahi-daemon[367]: Withdrawing address record for 194.171.31.228 on wlan0. Feb 14 11:11:21 Debian-Desktop avahi-daemon[367]: Withdrawing address record for 194.171.31.227 on wlan0. Feb 14 11:11:21 Debian-Desktop org.mate.panel.applet.MateMenuAppletFactory[730]: Fontconfig error: Cannot load default config file Feb 14 11:11:23 Debian-Desktop ntpd[3923]: Deleting interface #3 wlan0, 194.171.31.227#123, interface stats: received=41, sent=41, dropped=0, active_time=3142 secs Feb 14 11:11:23 Debian-Desktop ntpd[3923]: 192.16.191.36 local addr 194.171.31.227 -> <null> Feb 14 11:11:23 Debian-Desktop ntpd[3923]: Deleting interface #6 wlan0, fe80::c284:7dff:fe2e:be4e%2#123, interface stats: received=0, sent=0, dropped=0, active_time=3140 secs Feb 14 11:11:23 Debian-Desktop ntpd[3923]: Deleting interface #7 wlan0, 194.171.31.228#123, interface stats: received=0, sent=0, dropped=0, active_time=3136 secs
Also the following error: `Error getting the SSID`
Also just saw another error message that keeps coming up and I am not sure if it is related.
Feb 16 12:26:21 Debian-Desktop kernel: bcmsdh_sdmmc: Failed to Write byte F1:@0x1001f=01, Err: -5
Ok, looks like a different issue from the one I had. I'll try to check a local eduroam ap tomorrow.
(02-11-2020, 06:48 AM)oldmansaur Wrote: Hey everybody,
Edit:
I think is a problem of your eduroam spot, talk with your network staff.
I'm running my pinebook pro over eduroam right now without any problem.
With my pinebook non 1080p runs too.
I tried my local eduroam yesterday and saw the same  crash in brcmf_cfg80211_set_pmk I get with their normal WPA2 essid. So it looks like a different issue.
It's definitely an issue with the pinebook pro driver, since my x86_64 laptop and android phone have no trouble, but it probably depends on the details of the access point or authentication server implementation.
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 4 13,854 07-04-2025, 07:46 AM
Last Post: remph
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 19,527 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,681 03-15-2025, 01:47 AM
Last Post: frank_philip
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,539 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 5,031 08-21-2023, 09:10 PM
Last Post: vanessadonald
  5GHz wifi not working snorwood 11 19,189 01-16-2023, 03:41 PM
Last Post: ehcorn
  Pinebook Pro wifi not working Queliffrel 1 4,097 11-30-2022, 06:30 AM
Last Post: myself600
  WiFi stopped on Pinebook Pro after update tkudog 3 8,137 11-24-2022, 04:32 PM
Last Post: tkudog
  Archlinux - missing firmware for wifi adapter RudderDuck 9 16,538 11-07-2022, 04:56 PM
Last Post: wgahnagl
  Hibernation and Speaker Sound Issues, First Month of PBP kebab 7 9,262 11-02-2022, 02:33 PM
Last Post: kebab
