How to get kernel boot messages on screen on Manjaro
From a certain moment they can be seen if you change in boot.txt:
console=ttyS2,1500000n8
to:
console=tty1
and remove the bootsplash part so the line reads:
setenv bootargs console=tty1 root=/dev/nvme0n1p2 rw rootwait  (I have my root on nvme - your root might be elsewhere !!!)
Than - ./mkscr and reboot.
This is necessary for encryption to be able to enter password for your encrypted device.
I did your steps and did not see any messages at boot.. then again i don't have encryption set up, so this might be why.
You should be seeing messages whether you have encryption or not.
  Install Tow-Boot on the SPI Shad0w 13 8,185 04-19-2024, 12:20 PM
Last Post: alchemist
Question Can't Boot from MicroSD (What Am I Missing) falken 10 3,950 04-28-2023, 04:26 PM
Last Post: pinemouth
  Building PPSSPP with Manjaro AUR LivingLinux 0 1,167 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 13,591 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 3,251 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 7,147 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 3,441 10-02-2020, 12:20 PM
Last Post: wrzomar
  Extracting a copy of SPI NOR flash contents using micro SD card and u-boot hmuller 0 2,734 09-21-2020, 11:24 AM
Last Post: hmuller
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 3,455 09-21-2020, 10:02 AM
Last Post: hmuller
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 2,914 08-02-2020, 06:57 AM
Last Post: dieselnutjob
