Help: Keyboard and trackpad SPI update utility broke trackpad
Question
I ran ayufan's keyboard and trackpad SPI update utility (found here: https://github.com/ayufan-rock64/pineboo...rd-updater) I got the following error message:
update pass
QObject: Cannot create children for a parent that is in a different thread.
(Parent is QApplication(0xfffbe9dc), parent's thread is QThread(0xab2ca308), current thread is QThread(0xec1201a8)
I'm still able to use the keyboard on the PBP, but the trackpad behaves as through one of the mouse buttons is being held down. Then after a couple of uses the cursor seizes in place. I've tried running it again but I get more or less the same error. I can work around it for now by plugging in a USB mouse.
Does anyone have any guidance on how to re-flash the SPI, or know when the keyboard/trackpad update utility will be fixed?
Ben
I heard they were working on a firmware update for the keyboard, but I was not aware they had one available yet.
I think the SPI is un-used at this time on the PBP, but it is meant for booting purposes ?
I DO want to keep up on all the available updates....
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
There is no new firmware update for the trackpad/keyboard yet. @Feakster, where did you read it was to be flashed?
I'll see if I can get you the factory firmware again.
To all those reading this thread - DO NOT run the update utility. I'll let you know when we've got the firmware.
(11-10-2019, 07:35 AM)xalius Wrote: There is no new firmware update for the trackpad/keyboard yet. @Feakster, where did you read it was to be flashed?
Thank you.
Sorry. Must have misread something.
Ben
Following
I have done the wrong thing, too.
I'll follow this thread in the hope someone finds a solution for the trackpad.
The instructions in this thread solved the issue for me:
https://forum.pine64.org/showthread.php?tid=8407
Oh rats Step 2 didnt work, your instuctions didn't mention that you start in the wrong directory after a re-start......These instructions from so called "experts" are invariably incorrect...I should have learnt and not bothered . So...no trackpad...thanks
even you message board doesn't work....thanks
  pinephone keyboard oliveira11670 1 2,468 05-20-2026, 09:19 AM
Last Post: zetabeta
  Yet another new Pinebook keyboard problem MikoBob 3 5,611 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 4,859 02-17-2024, 07:06 PM
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 235,878 09-13-2023, 03:43 AM
Last Post: k3dAR
  Separate ISO keyboard for PBP Besouro 0 2,971 06-04-2023, 02:51 PM
Last Post: Besouro
  unable to boot after manjaro update gega 6 8,764 10-28-2022, 01:18 PM
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 3,032 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 6,895 02-15-2022, 10:12 AM
  Replacing the Keyboard gabb 6 12,789 01-11-2022, 07:39 AM
Last Post: Valenoern
  I broke my screen :( espenbo 3 6,253 01-03-2022, 03:46 PM
Last Post: altacus
