Manjaro for Rock64
Thumbs Up
Manjaro images are now available for download directly from the project's website.
Does not start, the monitor writes "invalid refresh rate of the screen", through ssh was connected but could not reach graphics settings by methods known to me (I tested version with KDE)
(04-29-2019, 07:41 AM)zet_lab Wrote: Does not start, the monitor writes "invalid refresh rate of the screen", through ssh was connected but could not reach graphics settings by methods known to me (I tested version with KDE)
Probably a good idea to let the devs know on their forum ...
new download link https://www.manjaro.org/download/arm8-rock64-kde/
now work, but resolution only 1080p
This distribution uses graphical acceleration?
(3d, acceleration video of video players and web browsers ...)
Added Manjaro KDE version 19.04 on Wiki and Pine64 Installer
Added Manjaro LXQT version 19.04 on Wiki and Pine64 Installer
Added Manjaro Minimal version 19.04 on Wiki and Pine64 Installer
I couldn't get the manjaro-arm-installer to work so I grabbed the 19.04 minimal image.   Flashed and booted fine.
Updated the keyring and uboot...rebooted and upgraded all to latest stuff.   Got 5.4.2 kernel atm.
No lima gles accel yet.  Working on it.
After a couple days of testing arch arm and manjaro arm  I've got what I wanted DE wise.   Manjaro installer  needs qemu ?   Went with a older image and updated it.    Works fine.   Lots of freezes with no log info.   Go back to Arch.
Same thing lots of freezes.   No idea why.  Heard its common to have power plug issues mines 5v 3a as recommended.
Network TX offload off   helps with ssh about it.    SDcards  tried usb hdd and 2 dif sdcards. that's not it.   v2 vs v3 boards the maker revised a resistor and pull up voltage on the nic port from 1.8.v to 3.3v.   Could be the issue.    Seems to not freeze longer if no DE is up that's for sure.
Got alarm working with lima driver (not llvmpipe) on both KDE Plasma and LXDE...but the freezes make them unusable.  I did nothing special with Arch arm to get the DE's up but use pacman and stable repos.
I'll try armbian and fedora next . If I cant find a non freezing OS I'll ebay this pos and leave arm alone.  Not worth the frustration.
I've got 4 of these Rock64s now...
One runs flawlessly. I hammer it to 100% CPU, max ram with some very intensive cryptographic toys and it never flinches. It's rock solid. No pun intended. I can't make it stutter no matter what I do. I absolutely flog it and it never hesitates. It impressed me so much I bought more.
The other 3 I bought won't even turn on. I've got two of the power supplies provided by the manufacturer, and also a nice Meanwell 5v supply capable of waaay more than 3A. Volt meter shows 5.0 dead on. I adjusted to 5.1, no effect. These 3 are just bricks right out of the box. No support. Completely ignored.
ArchLinux Arm. Armbian. Manjaro ARM. Nothing works. DOA.
Away
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,134 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 93,901 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 20,577 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,853 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,123 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,134 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,792 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,970 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,851 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 115,929 09-01-2024, 06:05 AM
Last Post: RaymondDay
