Which SD card should I use?
I've seen the user tkaiser link to an SD card performance thread a couple times (http://forum.armbian.com/index.php/topic/954-sd-card-performance/).  From what I understand, random I/O performance is the key factor for SBC use, but that is not something rated on the cards, so you have to test them.
But this text really stuck out to me:
"Always remember that there are a few renowned storage brands that just buy bunches of unknown flash chips to combine them with unknown controllers. Both performance and reliability might vary a lot between different batches"
and
"Then there exist manufacturers that own NAND factories, produce their own controllers, have engineers that do not just think about optimal combinations but realize them and ship final products. Think about the difference to the aforementioned group when buying cards"
So, how do you find which manufacturers just buy whatever, and which own NAND factories?  The thread didn't name them specifically either way.
For those of us newer to the SBC world, and the mentions of junk and fake cards out there, could anyone make a recommendation of which SD cards we should be looking at, and which to avoid?  I was going to use my old Sandisk Ultra 16GB that I had used in my phone previously, but I'm concerned it's not going to cut it.  And if I buy a new one, some suggestion on brands to look at (or avoid) would be greatly appreciated.  Hopefully, some of the other newer users could benefit from this as well.  Thanks.
(04-21-2016, 11:35 AM)montero65 Wrote: I've seen the user tkaiser link to an SD card performance thread a couple times (http://forum.armbian.com/index.php/topic/954-sd-card-performance/).  From what I understand, random I/O performance is the key factor for SBC use, but that is not something rated on the cards, so you have to test them.
and
tkaiser mentioned in another thread the Samsung EVO and Sandisk at least reliable, mine is a Sandisc 32gb and works fine, Samsung EVO seems better in i/o-speed, but i dont find the right thread at the moment. [emoji53]
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
  How to boot from SD card on pinebook pro linux123 3 10,293 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 7,067 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 7,146 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 10,265 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 300,691 03-03-2020, 11:34 PM
Last Post: siyatalerja
  eMMC card on adapter Malmgren 8 18,725 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 16,005 02-08-2017, 05:42 PM
Last Post: maxpayne
  recommended micro sd card? Gustavo Woltmann 1 6,104 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 6,048 11-03-2016, 02:33 PM
  SD card burn img size problems stephen0205 17 37,623 09-22-2016, 06:28 AM
Last Post: tkaiser
