PWM on rock64
I want to connect a strip of neopixels to the rock64 for a project.  I plan on using this: https://github.com/jgarff/rpi_ws281x
Physical pin 33 on the pi header is open so I want to use that.  That means I need PWM.  Is that pin able to do that on the rock64 or is that on a different pin?  Do I still need to disable onboard audio or is the a raspberry pi thing?  What DMA channels are available/unused?
If these should really be multiple threads, let me know and I'll break it up.  I didn't want to risk spamming the forums with multiple posts for one issue.
(11-24-2018, 12:06 AM)Mentaluproar Wrote: I want to connect a strip of neopixels to the rock64 for a project.  I plan on using this: https://github.com/jgarff/rpi_ws281x
Working on the same project. Haven't seen anyone get hardware pwm working on the Rock64. See Leapo's library for example of soft pwm, https://forum.pine64.org/showthread.php?tid=5902.
Doesn't work fantastically for LEDs though. I've been able to minimize the flicker by performing very slow transitions, and only operating on 1 or 2 channels at a time, but it's still occasionally noticeable.
Video
just tested basic soft pwm using C instead of python. Much better for leds. No noticeable flicker.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,505 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,118 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 97,618 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,123 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,636 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,627 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,009 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,192 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,075 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 118,537 09-01-2024, 06:05 AM
Last Post: RaymondDay
