Connect Official Wifi/Bt Module
Hi guys!
How you guys connect wifi through the official wifi/bt module?
I am using this image(Arch Linux Image with XFCE4 Base on Longsleep Image 20160304-1)
lspci -k or lsusb -v not working at all
Any idea? Huh
To start off, you will possibly need to use the Ethernet connection to get some packages using pacman (can't verify if this step is needed with this image):
pacman -S iw wpa_supplicant netctl
Next, you will need to load the driver module for the wifi board. To do this temporarily, run:
modprobe 8723bs
To have it loaded on each boot, add a file to /etc/module-load.d/ called 8723bs.conf, and add the text "8723bs" to the file.
If you check "ip link", you should now be able to see wlan0 and wlan1. From here, you can use either iw or netctl to configure your wifi settings.
https://wiki.archlinux.org/index.php/Wir...nual_setup
Is the procedure similar for Debian Jessie images? Thanks.
(04-20-2016, 10:24 PM)cbogdan Wrote: Is the procedure similar for Debian Jessie images? Thanks.
For Arch running Ubuntu 16.04, with MATE desktop image, I connected the module, and Wifi ran perfectly after boot up. BT is still buggy though.
  [split] Better WiFi/BT module? moriel5 3 10,552 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,764 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 43,177 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,233 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 33,827 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 16,821 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 3,562 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 6,171 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 24,812 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 10,097 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
