Tuning Rock64 - I need advices
Hi guys,
I misunderstood the real capacity of this board, I was convinced it was slightly below the Odroid-XU4 but I was wrong, so now I would like to try pushing this board to its limits. I meant to use it with Lakka, so I am focusing on best performance available.
Right now the only thing I thought (but I haven't done yet) is check out the governor, I was thinking to set up it to "ondemand" or "performance" (mostly the latter). I would like also to enable the full GPU clock. General safe overclock it would be great but I haven't found any relevant info, it would be great if it is possible enable a safe overclock like the PI boards family. My cpu and gpu have a passive heat cooling.
Thanks in advance,
D.
No one willing to help me? :'(
It is possible to run the board at a higher clock. But last time I saw it done was back in the day when pre-production boards were in the dev evaluation period. The reason is simple, for the slight improvement in performance you have to handle much higher thermals. In short, the drawbacks outweigh the benefits. I remember fire219 running the board with a big heatsink and a fan to get the board stable at (IRRC) 1.5Ghz ... It just doesn't make much sense.
(02-10-2018, 01:59 AM)Luke Wrote: It is possible to run the board at a higher clock. But last time I saw it done was back in the day when pre-production boards were in the dev evaluation period. The reason is simple, for the slight improvement in performance you have to handle much higher thermals. In short, the drawbacks outweigh the benefits. I remember fire219 running the board with a big heatsink and a fan to get the board stable at (IRRC) 1.5Ghz ... It just doesn't make much sense.
Got it, by the way the governor is already set up on performance, isn't there anything more I can do to improve the performance?
At this point any major improvements will be achieved by improving drivers, etc.
so how overclock can be done?
  Rock64 v2.0 u-boot SPI issues ju0n 0 321 07-05-2026, 11:02 AM
Last Post: ju0n
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,675 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 26,897 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 15,922 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 17,598 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,454 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,304 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,417 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,671 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,615 11-28-2022, 02:18 PM
Last Post: Macgyver
