Android TV
[Image: 76556b817108106262275636b707d916.jpg]
Is there any chance getting android tv to run on the pine?
Sent from my SM-G925F using Tapatalk
I put the android tv launcher on, works
http://www.apkmirror.com/apk/google-inc/...-download/
https://play.google.com/store/apps/detai...r&hl=en_GB
Excellent thanks will give it a go once my faulty pine is replaced!
(04-04-2016, 08:32 AM)lejaybo Wrote: I put the android tv launcher on, works
Hey! I've downloaded and installed the launcher - but how do you actually activate it on the Pine64.
Sorry if this is a daft question!
Sorry for bumping a really old thread, it's just I've been trying to do exactly this. I updated Google Play Services and anything else that may have needed updating, installed the TV version of the Google app and then installed the launcher. Whenever I try to return home to this launcher it just crashes.
Edit: This has happened on multiple versions of the official Android image.
I found that installing an older version of the launcher seems to work thoug a lot of the functions don't work.
The main issue is that apps don't detect it as "android tv". e.g plex. So plex doesn't look the same.
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,792 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 613,808 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,681 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,319 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,817 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,419 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,703 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,837 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 412,331 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,620 02-26-2019, 11:58 AM
Last Post: Twistedx
