pinebook xenial - module snd-usb-usx2y missing
I tried to use pinebook as audio recording machine with a tascam US122, which works fine with most linux flavours after installing alsa-firmware package. But the linux version shipped with the pinebook (upgraded to 3.10.105-bsp-1.2-ayufan-77) lacks the module snd-usb-usx2y, so the soundcard is not recognized.
Downloading the source (alsa-driver-1.0.25+dfsg) and trying to compile (when running configure) gives
. . checking for directory with ALSA kernel sources... /home/richard/Downloads/alsa-driver-1.0.25+dfsg/alsa-kernel checking for directory with kernel source... /lib/modules/3.10.105-bsp-1.2-ayufan-77/build checking for directory with kernel build... /lib/modules/3.10.105-bsp-1.2-ayufan-77/build checking for kernel linux/version.h ... no The file /lib/modules/3.10.105-bsp-1.2-ayufan-77/build/include/INCLUDE_VERSION_H does not exist. Please install the package with full kernel sources for your distribution or use --with-kernel=dir option to specify another directory with kernel sources (default is /lib/modules/3.10.105-bsp-1.2-ayufan-77/build).
I could not find out where to get the kernel sources or appropriate include file (version.h). So I'ld like to get some hints how to get/compile that kernel module.
Don't say pinebook is not usable for that task - I tried out with a focusrite saffire 6 USB and audacity, and that worked out of the box even with overdub in high bitrates.
Thanks for your support.
Edit: Linked ../generated/uabi/linux/version.h to /lib/modules/3.10.105-bsp-1.2-ayufan-77/build/include/linux/version.h, so configure could go on. But now it stops with "error: You have built-in ALSA in your kernel.". Does that mean I would have to compile the whole kernel by myself? I think it is not worth trying; if snd-usb-usx2y will not be included in the official kernel in the near future, I'ld have to get some standard compliant USB soundcard.
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 5 15,162 10-25-2026, 04:11 AM
  DietPi OS for Pinebook MichaIng 5 18,030 07-28-2026, 08:02 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 106,546 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 6,236 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,727 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 17,503 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,733 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 11,092 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,839 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,768 01-20-2021, 11:18 AM
