Unable to boot anything...
I bought a Rock64 4GB and an eMMC.
I am unable to boot the board.
I have tried booting the the board repeatedly using the eMMC and 3 different SD cards (and I have tried removing the eMMC and putting the switch on)
I have downloaded every image both hf and 64 bit, some several times. I have tried burning the SD and eMMC in different ways - using your PINE installer, etcher, disk manager, I have used linux and windows to do this. I have checked MD5s for downloaded files where available (community downloads seem to be missing these)
I have encountered three outcomes:
  1. Android boots and I can interact for maybe 20 seconds before the screen freezes I can't actually do anything in that time.
  2. Linux boots and then throws an kernel exception dumping stack trace, sometimes I can ctrl-alt-del to reboot to the same, sometimes I can't. I can only ever do that once.
  3. The 3 lights come on and nothing else happens.
I have tried 2 different power supplies.
If this was a PC I would be trying different memory as this reeks of memory corruption but of course I can't try that.
It feels like the board is at fault - am I missing something?
I've raised a ticket with Pine64.
Come meet me on the irc ( see address below ) and I'll help you live;
... the board might be bad;  however, I doubt it.  Let's talk live, there are some things I can have you check.
Shy
See you on IRC.
Sorry for disappearing from IRC, I fried my install on a the laptop I was on - I forgot it was using the SD card...
Anyway, tried script again but with different image, same result.
(08-20-2017, 02:33 AM)fontalamh Wrote: Sorry for disappearing from IRC, I fried my install on a the laptop I was on - I forgot it was using the SD card...
no worries;
You have a support ticket open;  pretty sure its a board issue;  I'll mention it to tllim too.
Blush
  Rock64 won't boot luminosity7 10 8,428 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 1,348 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 2,578 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 4,208 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,877 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  boot hdd usb3 philipe 1 3,650 01-27-2021, 02:12 PM
  Libreelec Rock64 - 4GB no boot spiker15 3 6,075 11-02-2020, 12:36 AM
Last Post: wilsonYan
  Rock64 - boot helpmerock 2 4,631 10-08-2020, 01:29 PM
Last Post: helpmerock
  No boot up after power on Whoopsadaisy 4 7,379 09-26-2020, 05:14 PM
Last Post: simonsouth
Bug u-boot (forks) status mcerveny 14 20,259 08-27-2020, 01:44 PM
Last Post: globaltree
