WiFi/BT to host wakeup pins?
Hi!
I had a quick look at what I assume is the datasheet for the Wifi/BT chip/module that is then mounted onto the Pine64 "breakout board" type module.
I found it on the Pine64 Wiki so I assume that's what it is; https://drive.google.com/file/d/0B0cEs0l...9kRDQ/view
There are two pins on the actual IC that caught my interest;
"WLAN to wake-up HOST" (13) and "Bluetooth device to wake-up HOST" (7).
Are those pins be reachable and somehow relevant/useful when connected to the Pine64?
In other words:
would we be able to power up the Pine 64 by sending a simple Wake-On-Wifi package or BT equivalent?
(I'm not sure if there are any smartphone apps easily available that lets us send a Wifi/BT host wakeup "magic package" though)
Being able to boot up the Pine64 that way would be pretty neat, since it could be as simple as a "shortcut" on your smartphone.
(03-11-2016, 09:34 AM)Tommy_2Tall Wrote: Hi!
In other words:
These two pins have been properly route to A64 SoC chip. However, I have not try out these interesting features myself.
Thanks for the reply!
Did some more "digging" over at the Wiki and found the PDF which describes all the connectors so I just came back to confirm that they seemed to be properly routed/"broken out".
Now we have that confirmation from you as well.
https://drive.google.com/file/d/0B0cEs0l...ItV2M/view
Seems like one more thing that will have to be tested later.
  [split] Better WiFi/BT module? moriel5 3 10,406 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,680 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 42,817 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,186 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 33,688 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 16,645 09-11-2018, 02:02 PM
Last Post: gamelaster
  Installing another WiFi module on one of the buses mido2018 1 6,121 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 24,605 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 10,019 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
Sad wifi direct bj_jung 2 8,445 12-29-2016, 10:26 AM
Last Post: happytuna
