pine64-debootstrap
Create a minimal Ubuntu rootfs from Longsleep's Ubuntu image using pine64-debootstrap. This is if you want to create a minimal server image (the way you want to roll it) with wifi instructions. Just a couple easy scripts and some interactive prompts to answer and you will have a rootfs archive ready to write to SD.
  Disable HDMI Pine64 Andruxa89 1 7,534 01-31-2019, 11:18 AM
Last Post: martinayotte
  Unable to run hello-world docker container on Pine64 kamtschatka 2 9,481 01-24-2019, 04:29 AM
Last Post: arboehm
  KDE on pine64? jamiechang917 6 16,449 01-14-2019, 01:47 PM
Last Post: brigmohan
  External DAC - Pine64 mjgoode 2 8,072 09-05-2018, 12:12 AM
Last Post: mjgoode
  Summer Undergraduate Research using Pine64's pkivolowitz 3 8,713 05-15-2018, 08:17 AM
Last Post: pkivolowitz
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 4,648 07-08-2017, 09:34 AM
Last Post: petec
  How to add kernel modules to Ubuntu 16.04 on PINE64+ Taiki Bessho 1 6,113 04-12-2017, 10:01 PM
Last Post: MarkHaysHarris777
  Node.js is not installed properly on Pine64 nsisodiya 1 5,704 12-29-2016, 12:48 AM
Last Post: longsleep
  Finally got Emby server running on Pine64 clarkss12 3 9,951 11-08-2016, 06:04 PM
Last Post: clarkss12
  Firefox on Pine64 S265 2 8,066 09-04-2016, 09:25 PM
Last Post: S265
