11-25-2023, 08:28 AM
(11-25-2023, 04:29 AM)Eugo Wrote: Okay, for good two hours of suspend-from-dropdown it lost only about 3%.
Still this is only marginally better
- the suspend from physical button doesn't suspend
- this suspend-from-dropdown is something I'll forget to do in a hurry
- the PowerSupply applet still shows 2,24W drain when idling with screen on
2,24W sounds normal - I get the same. Also top seems normal.
"Suspend from physical button" - if you mean power button (which will turn screen on or off?) it does not suspend your Pinephone with Phosh. It just turns screen on or off or power on or off. There might be a way to make it suspend but afaik no-one have ever got it working.
Phosh suspend works by default so that you set the automatic suspend timer which will suspend phone in that time if you (or some app who can inhibit it like calls) don't interrupt it. Then you can sure suspend manually trough "systemctl suspend" or from the quick settings button.
"Okay, for good two hours of suspend-from-dropdown it lost only about 3%.
Still this is only marginally better"
This sounds as good as it gets if you have modem powered on. Maybe you are just getting more accurate battery percentage now ?
