Pinephone & Nexdock
I got one of the Nexdock things that Purism is selling and I really like it.  I no longer need to tether the phone to a laptop for certain mobile uses - I can simply use the relevant apps and data directly on the phone now.  One odd behavior I am seeing is the screen going black for a couple seconds 2-4 times per minute.  I don't see this behavior when the Nexdock is connected to my Juno tablet (with mobian) so it's apparently not endemic to the dock.
Does anyone else have experience with a Nexdock and Pinephone?  I'd sure like to get some clues to the source of this issue.
For me modem activity will cause this on certain frequencies.
And for me those frequencies are 4G - with 3G or lower this does not happen.
This is also a "known" issue but really difficult (or impossible) to solve
De-coupling the shield on the connecting cable may help. Disconnect it on one end but not the other, if you can. (This likely won't be easy.)
Or try some snap-on ferrites.
:wq
I had an unexpected week on the road during which I was able to get much more use from the Nexdock, and I observed that the blanking happens either frequently/regularly or not at all.  It kinda seems like maybe it doesn't happen if the phone has been recently booted but I need to start keeping a log to see if I can get data rather than anecdotes.
  Pinephone visibly losing power while plugged in Hiraghm 10 10,431 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 2,195 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 89,448 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 27,301 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,289 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,884 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,588 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,212 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,612 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 9,083 10-21-2025, 12:12 PM
Last Post: Richy_T
