pinephone keyboard case how to use the = f8 - etc
Is there a guide somewhere on how to use the number rows 2 alternative keys?
i've tried multiple key combinations (pinekey/ fn alt ctr etc)
but i havn;t gotten it to work.
running on mobian latest atm
(02-05-2023, 11:15 AM)tuxcall Wrote: Is there a guide somewhere on how to use the number rows 2 alternative keys?
Have you tried adding 'XKB_DEFAULT_MODEL=ppkb' to the bottom of ~/.profile to activate the top row symbols. Reboot, or re-read ~/.profile w/
>source ~./profile.
Then you'll need to choose a key to use w/ F-keys for FN symbols...
Settings > Keyboard > Special Character Entry > Alternate Characters Key
To disable the virtual keyboard...
Settings > Accessibility > Screen keyboard
This doesn't stick between boots, but it's not much trouble, and the
advantaqe is that you don't have to remember to re-reactivate it before
taking the fon out of the keyboard and finding you don't have any input.
-jd-
thanks i'll try that out!
>source ~./profile.
-jd-
Ironically, you can't type in underscore '_' in the XKB_DEFAULT_MODEL. So I will edit the file on my Mac and then transfer it back Wink
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 3 5,910 10-15-2026, 08:04 AM
Last Post: Flymoon
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,633 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,296 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 11,247 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 27,724 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,600 10-07-2024, 11:08 PM
  Troubleshooting Pinedio LoRa Add-on Case nickp 2 4,629 09-29-2024, 09:17 PM
Last Post: lavabrilliant
  Getting started with fingerprint scanner case lolgzs 1 5,703 09-08-2024, 04:21 AM
Last Post: mfashby
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 24,118 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,575 07-04-2024, 10:22 PM
