Troubleshooting Pinedio LoRa Add-on Case
Hi everyone,
I am trying to run meshtasticd on my Pinephone.
Suddenly tough, the received bytes of the SX1262 are all zero, and I never managed to get the standard 0xA2 answer back.
I2C communication works still, which is why I am suspecting that the radio chip is at fault.
Does anybody know what I was doing wrong or how to debug this?
Onto the details, I simply implemented an SPI device driver which translates to I2C such that mestasticd can communicate with it as if the ATTiny bridge isn't there.
The code for the kernel driver and a dmesg trace with debug output can be found here: https://gist.github.com/pectec/ffddf32ae...041bc92bbe
Any help on this is appreciated Smile
Thank you,
Nick
Edit: I managed to damage it, Pine64 says that there isn't going to be a production batch anytime soon.
My only option is DIY at this point (using a [url=https://www.amazon.de/dp/B0CSFG65MS?psc=1&ref=ppx_yo2ov_dt_b_product_details][/url]Waveshare RP2040), which I'll do when I come around to it, so I'll mark this issue as solved.
(06-16-2024, 01:03 AM)nickp Wrote: Hi everyone,
Thank you,
Nick
You can check out with JF at chatroom, he implemented that Lora backcase i2c to SPI code.
Since you're getting all zeroes, it's worth ensuring that the SPI interface (used by the SX1262 for communication) is configured correctly. Even though I2C is working, the SX1262 primarily communicates over SPI.
  Pinephone (Pro) Keyboard Case for sale manubert 8 20,100 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,632 01-12-2026, 06:09 PM
Last Post: ragele
  keyboard case charging but not typing new2pinephone 19 28,517 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,859 10-07-2024, 11:08 PM
  Getting started with fingerprint scanner case lolgzs 1 5,886 09-08-2024, 04:21 AM
Last Post: mfashby
  Case for Pinephone totilele 13 23,562 04-11-2024, 11:48 AM
Last Post: gramonyl
  Slip/Zippered Case for PP/KB? jakfish 0 2,687 03-03-2024, 04:55 PM
Last Post: jakfish
  Getting all keys working on pine phone keyboard-case undata 5 9,526 10-08-2023, 12:19 PM
Last Post: mburns
  PinePhone Wallet Case Shane 5 11,365 09-17-2023, 12:52 PM
Last Post: J T
  pinephone keyboard case how to use the = f8 - etc tuxcall 3 5,976 05-02-2023, 05:18 PM
Last Post: undata
