Rii mini 4 keyboard and touchpad work over Bluetooth
Why to be smart if Bluetooth works?
I thought that the Rii mini 4 with 2.4 Ghz dongle would be the ultimate solution to solve the Pinephone keyboard problem. After a sleepless night in which I tested 6 cheap Aliexpress docks in all configuration with usb keyboard and mouse, none of the worked. Some time ago, one of them worked with usb keyboard and mouse, but I could not reproduce it.  I thought a Rii mini 4 with 2.4 Ghz dongle would eventually the solution for the Pinephone keyboard problem together with the docking sation:
https://forum.pine64.org/showthread.php?tid=19350
But in the morning I decided not to buy any further Pinephone accessoires for a Pinephone I never use and put on the screed and take it down again for some tests.
In the afternoon, I thought,  why not to try the Rii 4 over Bluetooth? Reports of Zebulon Walton about a Bluetooth mini keyboard where horrible:
https://forum.pine64.org/showthread.php?...316&page=2
Now i paired the Rii 4 mini over Bluetooth to my Pinephone with postmarketOS. There where no disconnection issues during 3 min tests as where reported with other Bluetooth keyboards:
https://forum.pine64.org/showthread.php?tid=13835
Keys, touchpad and scrollweel worked. One user reported to have issues with connecting a Bluetooth keyboard and mouse at the same time. Only one device worked, either keyboard and mouse.  Other reported that Bluetooth keyboard and mouse work with Logitech devices:
https://forum.pine64.org/showthread.php?...316&page=3
But Logitech has not mini keyboards. The Rii mini 4 is a mini keyboard with dual mode BLE and 2.4 Ghz dongle. I did not get to work the 2.4 Ghz dongle, but the keyboard with touchpad.
The Rii 4 over Bluetooth is the best experience for a Pinephone keyboard for me personally to this date. It is available and worked for 3 min. reliably. And it has also a layout with many keys, similar to the Pinephone keyboard which makes it  a great device. The keyboard is not much bigger than the Pinephone, and fit’s in a pocket.
There is also the EASYTONE Mini Wireless Keyboard which I found worked with the USB connection on my Mobian Bookworm 3GB pinephone.
But I think I may get the Rii if it is narrower - I need a keyboard less than 75mm wide to try to stuff it in my Gamesir Nova Lite Phone holder (maybe with some added foam padding), so I can type while walking around!
OK here is a keyboard -  phone holder combination that allows you to clamp the keyboard in the custom bracket meant for the game controller, while the Pinephone is securely clamped in the spring-loaded bracket:
- 8Bitdo Mobile Clip for SN30 Pro Bluetooth Controller
-  Rii Mini Keyboard,Wireless Keyboard with Touhpad,Keyboard Remote for Smart TV,Android TV Box,PC,Laptop,Windows,Mac
Note the keyboard has to be fitted in at an angle - it will snap securely into place, as long as the phone bracket is swivelled and locked in at the right angle.
The weight balance is a little phone heavy, but it does turn your pinephone into a pda with attached keyboard!
(07-19-2024, 08:02 AM)Peter Gamma Wrote: Why to be smart if Bluetooth works?
It’s great that Bluetooth worked better than the USB docks you tried. Sometimes the simplest solution turns out to be the best one. The Rii mini 4 sounds like a good option for the PinePhone, especially because it’s small and easy to carry around. I’d be interested to know if it continues to work reliably after longer use.
The 8Bitdo clip approach is interesting, but I'd worry about the angled fit stressing the keyboard's casing over time. Peter's point about the 2.4 GHz dongle failing while Bluetooth works matches what I'd expect on postmarketOS — the dongle path depends on dock USB behaving, which is clearly flaky. Three minutes of Bluetooth without drops is a good sign, though I'd want a longer session before trusting it. One thing worth checking: whether the touchpad and scrollwheel stay responsive after the phone suspends and resumes, since that's often where Bluetooth HID pairing gets lost.
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,901 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,519 01-12-2026, 06:09 PM
Last Post: ragele
  keyboard case charging but not typing new2pinephone 19 28,143 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,753 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 24,635 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  How to get the Rii 4 with 2.4 Ghz get to work with the PP Peter Gamma 1 3,496 07-18-2024, 10:48 AM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,584 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,407 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 5,281 06-29-2024, 09:36 PM
  Bluetooth keyboard with trackpad Zebulon Walton 11 24,477 06-29-2024, 04:09 AM
