Need help with new pinebook pro
Ok, so I've downloaded the image
https://github.com/manjaro-arm/pbpro-ima....06.img.xz
and wrote it to a USB drive.
Then booted the pbp using it and installed manjaro on the USB drive.
Booted again, tested everything included wifi and all is good.
Now I want to flash this very same manjaro I am using from the USB to the eMMC. The problem is that "manjaro-arm-flasher" is not installed by default in the USB. If I try to sudo pacman -S it fails to retrieve some packages (python related) and the installation is aborted. I am not sure what version of flasher corresponds to this version of manjaro so anyone can provide a URL?
Thanks.
(09-05-2022, 09:30 PM)steeb Wrote:
(09-05-2022, 11:33 AM)magistral Wrote: The issue I have at this moment is that I cannot make manjaro to recognize the wifi card. I've tried many flavors of versions 22.02 & 22.04 from that link.
See this post on the Kali Linux forum for WiFi drivers: https://gitlab.com/kalilinux/build-scrip...1069959116
Copy the files to
/lib/firmware/brcm
and you'll have WiFi.
This has worked for all distros that I've tried so far, not just Manjaro, so keep these on an SD card!
Thanks for the hint, but that does not work for me.
The installed version is manjaro 20.02, which is the only version I can install to the eMMC and boot the pbp. Every other version I've tried to install to the eMMC for one reason or another, fails to install or boot.
At this point I think I have a faulty pbp.
The only two versions that work with this damned pbp are:
Manjaro-ARM-xfce-pbpro-20.02-emmc-installer-20.04.img.xz
and
Manjaro-ARM-xfce-pbpro-20.04-emmc-installer-20.04.img.xz
Are there any newer "emmc-installer" version than 20.04?
  Debian on Pinebook Pro u974615 7 1,002 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,577 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,139 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,212 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,605 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,229 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,254 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,480 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,582 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 660 07-13-2023, 05:21 PM
Last Post: owaspfap
