Trouble building (& using) pinephone-keyboard tools
I'm trying to build the pinephone-keyboard package on PostmarketOS, so I can see the keyboard's battery with one of its commands. After installing php and gcc to solve the dependency errors I was getting, I got stuck on one I couldn't figure out:
In file included from i2c-inputd.c:22: common.c:20:10: fatal error: linux/usbdevice_fs.h: No such file or directory
I did a search and found the file in a GitHub repo that's supposed to be a Linux kernel - I don't know much on the subject, but I assume this means getting the tools to compile will be more complicated than a simple apk install... Unless, by some miracle, make's just not finding the header file hidden in some system folder Undecided
Anyone got any ideas? Cheers
(05-22-2022, 12:18 AM)64_Tesseract Wrote: I'm trying to build the pinephone-keyboard package on PostmarketOS, so I can see the keyboard's battery with one of its commands. After installing php and gcc to solve the dependency errors I was getting, I got stuck on one I couldn't figure out:
Install the
linux-headers
package.
Compiled without issues, thanks!
Forgive me for peppering you with questions, but I have been (very!) curious about this as well.
1. Does it work?
2. I thought it also required some kernel support (but maybe that's there already)?
3. What distro / shell / version of PMOS are you on (I am on SXMO 1.9.0)?
I don't even see /sys/class/power_supply/ip5xxx-*, so I am wondering if I fried my chip, or maybe I just don't have recent enough kernel.
Cheers,
TRS-80
Protocols, not Platforms
(08-15-2022, 07:30 PM)TRS-80 Wrote: Forgive me for peppering you with questions, but I have been (very!) curious about this as well.
1. Does it work?
I've got SXMO 1.8.2 on the original PP, and I think PostmarketOS should already have support for the keyboard considering it receives inputs & all. I only just got around to trying the tools out, but unfortunately I'm not having much luck Sad
If I try running ppkb-i2c-charger-ctl with any command, it just gives me a very helpful
ERROR: Proxy read failed with ff
I'm not seeing /sys/class/power_supply/ip5xxx-* either but i2c-adapter has a bunch of stuff in it, so the keyboard should be accessible from one of those folders.
I am pretty sure the power management (ip5xxx) kernel support is not there (yet) in Stable SXMO (which is what I am on; 1.9.0).  Not sure about Edge.  The keyboard works though (as an input device).
More details can be found in a recent post I made to sxmo-user mailing list.
Cheers,
TRS-80
(08-23-2022, 04:17 PM)TRS-80 Wrote: I am pretty sure the power management (ip5xxx) kernel support is not there (yet) in Stable SXMO (which is what I am on; 1.9.0).  Not sure about Edge.  The keyboard works though (as an input device).
I read through your post and actually, I'm having the same issue as you - the PP discharges faster with the keyboard than without. It used to charge the phone fine when I got it a few months ago, but it died not long after, even when I followed the warnings & only charged it through the keyboard.
I tried shimming it with board from a few directions, but I'm afraid I might've damaged the cables, so I wanted to check if the problem lay in the battery itself or just the connection with these tools. Never got around to using a multimeter either since I wouldn't know what to look for in the first place...
Oh well, guess I'll be using an external battery pack & repeatedly replacing the back cover until SXMO's updated lol
  asterisk or FreePBX on pinephone? vanja 0 994 06-16-2026, 09:24 AM
Last Post: vanja
  Jami on Pinephone [ IM and VOIP ] p1trson 15 25,849 06-16-2026, 05:02 AM
Last Post: marlboro1950
  Movuan distribution for PinePhone merom 6 8,311 06-04-2026, 02:10 AM
Last Post: merom
  Latest firmware for PinePhone modem! Subsentient 106 249,750 04-03-2026, 08:37 AM
Last Post: baptx
  Fedora + Phosh for PinePhone njha 77 236,193 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,488 11-17-2025, 07:49 AM
Last Post: danm1988
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 4,861 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 73,039 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 6,316 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 83,352 07-26-2024, 10:35 PM
