Pine Media Remote
Has anyone figured out how to connect this thing to their pine? There were no instructions given. I assumed it was bluetooth connected but the BT doesn't pick it up. Is there something I've missed?
(07-03-2016, 08:33 PM)mesaxi Wrote: Has anyone figured out how to connect this thing to their pine? There were no instructions given. I assumed it was bluetooth connected but the BT doesn't pick it up. Is there something I've missed?
Hi. I do not have the media remote myself, but the Pine shop here describes it as an IR (infa-red) device with IR receiver, that takes 3 x AAA batteries. Thus, if you insert batteries and connect the receiver in the appropriate slot on the board, it should work.
See this diagram for where the receiver should be connected (on the right hand side, near the lower edge of the board).
Thanks on the explanation. The IR remote control takes 2 x AAA batteries.
I see now, thanks!
For anyone who's wondering, the IR Sensor was loose in the bag when I received it. It's an object with 3 pins that are ridiculously long. You can keep them that way, but I cut them down about half way to fit the sensor in the enclosure.
  Pine a64+ power supply davidspencer 0 2,946 03-18-2026, 01:02 AM
Last Post: davidspencer
  Pine A64+ lost 7" screen functionality after kernel 6.1 Learnincurve 0 1,802 12-10-2025, 09:03 AM
Last Post: Learnincurve
  Pine 64 installer OS list blank spamsucks 1 13,609 04-08-2025, 08:16 AM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 7,285 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 3,961 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 11,634 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 11,724 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 8,378 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 8,600 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 13,964 12-06-2020, 03:53 PM
Last Post: junkyj753
