Megapixels - Camera App - Works w. Beta NOT Pro
The MegaPixel app won't come up using the PPPro.   It does activate on the PPBeta.
I'm using Manjaro/Phosh Dev on both and update daily.
Appears to not be working on Arch either... had been working around 2 weeks ago
The version of Megapixels that Manjaro ships for the PPP is working (but the image quality is still bad, since there is no post-processing. Any picture i've taken so far had to be processed in darktable to get some color accuracy and contrast). Since i'm on Mobian i just downloaded the latest Manjaro-ppp image and mounted it to copy the config and binaries over to my ppp.
For myself, with daily updates from the unstable branch of Manjaro Plasma, the megapixels-ppp package must be installed in order to replace the megapixels package.
$ sudo pacman -S megapixels-ppp
But this is not sufficient at the moment. The device tree seems to need work.
  Back/World camera working after suspend DrYak 2 887 11-14-2023, 09:44 AM
Last Post: DrYak
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 715 11-07-2023, 09:44 AM
Last Post: mburns
  Booting from SD Works for Installers, not OS's ?? Diagon 3 1,163 08-13-2023, 03:27 AM
Last Post: fxc
  Manjaro as shipped & camera? hambonius 1 905 06-20-2023, 02:26 PM
Last Post: fxc
  Megapixels tuning mburns 18 6,824 03-18-2023, 07:26 AM
Last Post: mburns
  Megapixels on kernel > 5.19? timonoj 1 1,449 01-30-2023, 05:36 PM
Last Post: Piotr
  Megapixels (kernel 5.19) reports that a config file is missing. grump_fiddle_reinstall 2 1,856 11-30-2022, 07:44 AM
Last Post: mburns
  PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls X0X0X0X0X0 0 1,103 11-02-2022, 02:09 PM
Last Post: X0X0X0X0X0
  Manjaro Plasma Beta 11 sleep issue after 3/22 update Fred Zyphal 6 3,970 05-22-2022, 12:37 PM
Last Post: magdesign
  Stable Beta Factory Release Emilio 1 1,548 05-15-2022, 08:38 PM
Last Post: MichaelGriffin
