SFOS 4.1.0.24 aarch64
The new image is an aarch64 build, so quite a departure and there are many teething problems at the moment.
Flash as usual and then as root zypper ref/ssu ur/zypper dup. Apps now need to be 64bit builds so some on the Jolla store won't install and the Openrepos Storeman app will not install either. There may be some improvement in sim card recognition but it will take some time for this build to get back to parity with the 32bit version.
Hello, I downloaded the following Storeman file from Open repos and it is running now.
harbour-storeman-0.2.7-1.sfos4_.1.aarch64.rpm
(07-23-2021, 04:48 AM)OhneZ Wrote: Hello, I downloaded the following Storeman file from Open repos and it is running now.
Thanks, you're right, I didn't zoom in enough and just took the one nearest the end without looking carefully.  I just installed Sailtrix matrix client from openrepos, so works fine. Have you tried a simcard?
(07-23-2021, 05:35 AM)defactofactotum Wrote: Have you tried a simcard?
What should be the difference? Here (unlocked SIM) it looks like in previous version - at first start mobile network related items are present in desktop&menus, at the following (re)starts they are missing. Calls and SMS-s seem to work as in 4.0...
Thanks for the new version Smile
As of today morning installed available updates. The UI is very fast, fluid and smooth although running from the SD card.
Made some tests with telephony:
1. Can not call numbers with country code. Without it calling succeeded. Receiving calls worked.
2. Could not send a SMS. Receiving SMS's worked.
3. Still no UI elements for mobile operator and no corresponding menus in Settings.
Browser displays white pages and also e-mail bodies are not displayed. Webcat sort of works.
Your work with the port is highly appreciated Smile
Edit1: I have not found a regularity, but sometimes the telephony related items are present. Especially after forcing a shutdown after UI crash, when phone does not wake up after entering a powersave mode...
(07-27-2021, 01:09 AM)acrux Wrote: 3. Still no UI elements for mobile operator and no corresponding menus in Settings.
Edit2: It somehow improves in time Big Grin Last system starts have been all OK.
Edit3: Sending SMS seems to work OK now.
  SFOS 4.5.0.19 improved call audio and camera defactofactotum 1 4,116 08-31-2023, 03:29 PM
  SFOS 4.4.0.72, with calls defactofactotum 5 7,959 04-21-2023, 05:22 AM
Last Post: crocspot
  SFOS 4.3 wryun 4 7,977 03-25-2022, 03:24 PM
Last Post: Maus
  SFOS 4.2 defactofactotum 10 16,399 10-04-2021, 03:26 AM
Last Post: acrux
  SFOS 4.0.1.48 defactofactotum 8 15,793 06-01-2021, 01:42 PM
Last Post: OhneZ
  Img now updated to sfos 3.4.0.24 defactofactotum 8 16,280 11-08-2020, 12:53 PM
Last Post: clover
