Img now updated to sfos 3.4.0.24
The PP image is now updated to 3.4 so the info below is out of date.
You can update the sfos version on the pinephone by running the following commands:
devel-su
ssu re 3.4.0.24
ssu ur
zypper ref
zypper dup
NB this can take 3hours+ on sdcard, about 40 mins on emmc.
This build feel a bit faster. Patchmanager doesn't work.
Many thanks. I's prefer the URL to an image that can be copied to sd-card.
Many thanks. I'd prefer the URL to an image that can be copied to sd-card.
(10-20-2020, 03:44 AM)defactofactotum Wrote: You can update the sfos version on the pinephone by running the following commands:
devel-su
what password do you use for devel-su ?
The password the I had set for the nemo user didn't seem to work for me ....
(10-20-2020, 11:01 AM)Kawayuppie Wrote: what password do you use for devel-su ?
The one you set, there's no other. What response did you get when you entered it?
I thought it should be. I checked on the jolla SFO forum ...
Just behaved as  if I had the password wrong.
I double checked. Then it I think I broke something, so will check later today.
You need to set a password for devel-su in the developer options. It's not the pw with which you sign in.
Wink
(10-21-2020, 10:56 AM)Veraendert Wrote: You need to set a password for devel-su in the developer options. It's not the pw with which you sign in.
Yes, once sorting that out it is working. Info is also available on the Jolla forums ... my bad, RTFM Tongue
devel-su
ssu re 3.4.0.24
ssu ur
zypper ref
zypper dup
Thank you for this
Thanks for this, I actually have sound now and a reliable battery indicator. Two huge plusses!
Couple things i noticed broken on this version:
- Opening email from the Mail app causes app crash. Stills works fine for notifications though.
- Trying to log in to Google account on webcat causes browser crash.
- Possibility to turn brightness all the way down (blanking the screen), which does not get reset on reboot. so good luck if you do this!
  SFOS 4.5.0.19 improved call audio and camera defactofactotum 1 4,084 08-31-2023, 03:29 PM
  SFOS 4.4.0.72, with calls defactofactotum 5 7,926 04-21-2023, 05:22 AM
Last Post: crocspot
  SFOS 4.3 wryun 4 7,953 03-25-2022, 03:24 PM
Last Post: Maus
  SFOS 4.2 defactofactotum 10 16,240 10-04-2021, 03:26 AM
Last Post: acrux
  SFOS 4.1.0.24 aarch64 defactofactotum 5 10,328 08-13-2021, 12:13 AM
Last Post: acrux
  SFOS 4.0.1.48 defactofactotum 8 15,690 06-01-2021, 01:42 PM
Last Post: OhneZ
