are you supposed to be able to remove & put back the keycaps?
Before I pull on them and maybe break it;
Are you supposed to be able to remove & put back the keycaps of the Pinebook pro?
If so; just pull on them?
no, the keycaps aren't made to be user-replaceable. you may be able to, but you risk breaking them, which will require a new complete keyboard/palm rest assembly to replace.
Thanks!
Then there goes my plan to make a freak 'US default AZERTY' keyboard from it.
Question Powering off & won't power back on w/o battery disconnect jimsurvak 5 10,074 11-10-2020, 08:42 PM
