Pine power firmware
Hi
There are some elements of the display behaviour on the pine power I dislike. Is the firmware opensource so that I can fix it, please?
What do you dislike?
The wiki does not document any firmware, just an image showing the rear of the LCD panel -- there are two unmarked ICs (U4 and U5). I do not know if these are re-programmable it may be a difficult process even assuming the programming could be re-applied (they may even be programmable only once).
The screen power down behaviour mostly - if the PSU is on, I want the screen to stay in unless I press the screen off button, and if the screen is off then I want the screen off button to turn it back on.
Currently I have to physically look at the power switch to tell if it is on, and the screen sometimes comes on when wireless charging and sometimes doesn't
  What about a Pine digital audio player? ClairelyClaire 9 12,869 11-12-2026, 02:47 AM
Last Post: NorrisFByrd
  Question about firmware updates on Pinecil V2 helengrace 1 2,781 10-16-2025, 10:41 PM
Lightbulb Product idea: Pinebank, 18650 multifunction power bank/speaker/light/etc cowsay 0 2,112 10-03-2025, 11:35 AM
Last Post: cowsay
  Pine.org very poor review rma00 9 13,152 07-07-2025, 12:06 PM
Last Post: dachalife
  Optimizing Power Management on PinePhone with PostmarketOS ZaraAbbas 0 4,092 05-27-2025, 01:49 AM
Last Post: ZaraAbbas
  Replacement international plugs for 65W GaN Pine Power Cadair 1 4,446 05-20-2025, 10:20 PM
  Plans for higher Power PinePowers PMARC14 1 4,960 04-08-2025, 08:31 PM
Last Post: colajuices
  Pine Desktop PowerSupply wont power on BSharp 6 8,755 01-07-2025, 08:04 AM
Last Post: skare
  Help with high voltage power supply setup for electrospinning? namarang 2 5,539 10-13-2024, 09:38 AM
Last Post: zetabeta
  Pinebuds Pro Sound Firmware Update deMangler 0 3,218 05-12-2024, 06:14 AM
Last Post: deMangler
