pinebook pro trackpad randomly stops working
Running Manjaro ARM i3-edition on my PineBook Pro. Just received the device a few days ago.
At first I noticed that the trackpad's palm rejection wasn't quite there, but then I noticed that it was suddenly great -- not just palm rejection, but finger rejection, button press rejection -- it stopped working altogether!
Well, I run i3wm, so I don't use the mouse all that much. I just kept trucking on the terminal, and then the cursor started randomly moving around again according to the movement of my palms as I typed.
So, the trackpad seems to randomly cut in and out every few seconds -- BUT! I can keep the touchpad "alive" if I constantly mouse around in little circles. But sometimes I have to wait for a while for it to come back once it goes to "sleep."
Any ideas?? I saw a post about touchpad drivers, but the 2021 units are supposed to be pre-updated.
Just to re-iterate, the trackpad is completely dead every few seconds. Not only non-responsive to touch, but also to physical clicks with the trackpad buttons.
You could try a different operating system on micro SD to eliminate the OS and it's "firmware".
(05-07-2021, 12:39 AM)KC9UDX Wrote: You could try a different operating system on micro SD to eliminate the OS and it's "firmware".
Actually, I figured it out this morning. Super simple. The powersaving mode for the keyboard USB device was shutting off power to the trackpad.
I changed the parameter in `powertop`, and bingo! it was fine. Wink
Palm rejection still kinda sucks, but I guess I can live with that Big Grin
Please put that in the wiki, if you can.
(08-06-2021, 02:30 PM)bikerlatt1 Wrote: Hey all is there a final word on whether or not the trackpad issues can be fixed through software or is this a permanent issue with the hardware that cannot be fixed? It might sound like I'm complaining but just looking for a answer as to if I should wait for a fix or go ahead and mod in a USB trackpad to replace the one onboard.
Have you seen this thread? https://forum.pine64.org/showthread.php?tid=14531
The new update definitely did it for me. It's not 100% perfect, but it's good enough that I don't have to use the old python touchpad hack script that someone kindly wrote a while back.
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 7 10,925 10-05-2026, 12:42 PM
  Replacement battery for PineBook Pro DrYak 5 9,638 02-28-2026, 09:17 PM
  pinebook pro dixplays vertical stripes WEF 2 5,240 03-23-2025, 03:31 PM
Last Post: WEF
  "PowerButton pressed" randomly CosmicRay 5 6,808 03-09-2025, 08:23 AM
Last Post: CosmicRay
  New Working nVME gilwood 1 4,565 11-17-2024, 04:24 AM
Last Post: reukiodo
  Yet another new Pinebook keyboard problem MikoBob 3 5,837 09-11-2024, 07:05 AM
Last Post: MikoBob
  Pinebook Pro on Debian 12 Power Issue u974615 1 5,015 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 5,083 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 4,050 01-05-2024, 08:40 PM
Last Post: tomekdev
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 240,329 09-13-2023, 03:43 AM
Last Post: k3dAR
