Unable to turn off auto brightness at times
I am sometimes unable to turn off auto-brightness for the display.
And while this in itself would not be a problem, it tends to decide on its own to turn the brightness all the way down making the display difficult to read in bright light.
This usually happens when I am at an extreme in brightness.  For example, out in the sun.
I use the tap-down at the top of the display and set the brightness back to something reasonable and over a few minutes it pulls the brightness back down to minimum.  The behavior is repeatable.
Over in Settings when I try to disable auto brightness the button slides over to the left but does not turn grey.  It stays blue.  And I can see the brightness setting bouncing around.
Next if I go inside where the ambient like is not shall we say extreme, the auto-brightness button can be turned off.
I am wondering if the button has trouble working right when the brightness it is reading from the sensor is at an extreme end of its scale?
  Unable to wake up from suspend xavi92 6 7,193 07-28-2024, 02:48 PM
Last Post: dchang0
  Screen auto-rotation sensitivity mdk 0 2,376 12-26-2023, 06:08 AM
Last Post: mdk
  Auto start application on Phosh login Zebulon Walton 8 12,469 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 4,049 07-07-2023, 03:29 AM
Last Post: jojuma
  Unable to send messages with chatty user641 0 2,246 09-07-2022, 04:35 AM
Last Post: user641
  New SD card won't auto-mount, will only mount as read-only 3x5co 3 4,952 07-16-2022, 02:28 PM
Last Post: dachalife
  Automatic Brightness Stuck On biketool 3 5,810 04-05-2022, 11:49 AM
Last Post: henrythemouse
  Programs unable to open display via sudo or pkexec (linssid not working) Zebulon Walton 4 8,468 01-17-2022, 01:58 AM
Last Post: vusra
  any way to turn off authentication on pinephone? quixote 5 7,082 10-30-2021, 04:13 PM
Last Post: Frexit
  Anyone find a work around for the brightness issues from kernels 5.13/14? ragreenburg 2 4,882 09-01-2021, 08:49 AM
Last Post: ragreenburg
